Introduction: SPROUT STATION: Farmers Market Stand to Garden Bed
About: you know me
Cities face a dilemma when hosting temporary events, which is how to build infrastructure that serves a short-term need without creating waste.
My solution? A farmers market stand that transforms into a modular garden space! This instructable details the design process for a structure that’s not only functional during temporary market days, but also evolves into a sustainable green space afterward.
This transformation function emphasizes adaptive reuse, sustainability, and innovation. And the project reflects the benefits of reducing waste, and promoting eco-friendly practices, improving our cities into the future.
Step 1: Research - Market Stands:
Farmers markets are inherently temporary events, with vendors selling products in the warmer months, while the produce is of higher variety and quality. So understanding the needs of these vendors is crucial for designing an optimized solution to fulfill their requirements, without creating waste.
  1. Market stands require the ability to effectively display and showcase products, usually utilizing shelves, tables, or tiered displays. Hooks or racks for hanging items is also an important feature.
  2. An opportunity for “over the counter” interaction with the customer is crucial for establishing connections and communicating for sales. This is usually facilitated by having a countertop or designated table.
  3. Space for visually appealing features like signage such as chalkboards or banners is usually greatly appreciated. This can be used for decoration and/or to display names, prices, certifications, etc.
  4. Clear sightlines for customers to browse without crowding.
  5. Optional sun shielding/protection for vendors and/or customers.
  6. ADA-Compliant height for counters and accessibility for wheelchair users.
  7. General structural rigidity and resistance to elements such as wind, rain, and other precipitation.
Step 2: Research - Garden Beds:
The benefit of converting the farmers market stands into modular raised garden beds is that they can serve a purpose outside of the market seasons.
  1. Eco friendly materials like reclaimed wood, recycled plastics, or non-toxic composites. Reusing the structure from the market stand contributes to environmental mindfulness.
  2. High durability with reinforced corners and weather resistant finishes. (Natural Oil Stains)
  3. Easily accessible beds that can be rearranged to accommodate different environments/locations.
Step 3: Sketches/Concept Development
Key Design Goals:
  1. Quick Assembly (Under 1 Hour)
  2. Modular Components
  3. Dual Functionality
  4. Eco-Friendly Materials (Reclaimed/Recyclable)
  5. Visually Appealing
Step 4: CAD
In order to configure and verify crucial dimensions, I use CAD software to create a detailed model of each component, and double check both arrangements.
These models are also critical for visualizing the finalized project, an important step in conveying the core idea to consumers. Later during the design process, the models can be rendered or visualized with AI to be placed in an example environment, to demonstrate the ideal use case, and communicate the context behind the design.
The next steps cover the process from sketch to finalized assembly.
Step 5: Dimensioning
Dimensioning is the important step of defining critical measurements, assisting in further developing the scale and relationship of different parts in an assembly.
For this project, a side profile of the market stand configuration was selected to be the most intuitive and helpful model to dimension first.
I started with scaling the height of the stand. At 7ft, the back assembly will be a useful height for the stand, and serve as a long garden bed for plenty of plants.
Many other dimensions were selected at this stage as well. And due to basing every extrusion off these master sketches, dimensions can be easily updated later on.
Step 6: Back Assembly
After extruding each part for the back assembly of the market stand, they can be manipulated and connected in a new assembly.
Separating these assemblies in CAD is helpful as they can be easily reoriented to accommodate both configurations. The back assembly was the most complex, so I assembled and verified it first, so the front assembly can be created accordingly.
The back wall is composed of many reclaimed wood planks. These are deliberately placed with gaps in between to allow for accessories such as baskets, shelves, or signs to be easily hung and removed.
Step 7: Front Assembly
The front assembly was created in essentially the same process as the back assembly, however with less parts.
The front of the stand is made of 2 separate parts, the large support and the surface that rests on top. The support is used as a structural component for the garden bed, and holds up products when in the market stand configuration.
The top surface is not utilized in the garden bed configuration, and can be stored underneath for later use.
Step 8: Market Stand Configuration
The market stand configuration uses the most components, as it consists of the back assembly, both elements of the front assembly, as well as two side rails to help hold everything secure and keep the back assembly upright.
This configuration allows ample room for modular shelving on the back wall, and storage underneath the front desk.
Step 9: Garden Bed Configuration
The garden bed configuration turns the back assembly over horizontally, resting the cantilevered end on top of the front assembly. The main body of the garden bed slots neatly in between the sides of the front assembly, creating a sturdy, robust structure.
Due to the height of the front assembly, and length of the back assembly, the bed sits level in this configuration, creating a cohesive and modular system.
A tarp can be used to contain soil and other materials to foster healthy plant growth outside of the market season.
Step 10: Customization
A critical feature for both market stand and garden is customizability. Since vendors need to be able to change their displays depending on their products. And growers need to arrange their beds to their individual spaces.
The array of planks on the back of the market stand allow for the attachment of various accommodating items. For example, baskets, shelves, hooks, or signs made from reclaimed wood or recycled plastics.
The size of the stand accommodates a standard plastic foldable table, as seen at many current farmers markets. This provides a simple, reusable place for vendors to put belongings and other materials.
In the event that a vendor needs more space for products, two market stands can be placed side by side, to effectively create a wider stand.
In the garden bed configuration, they can be rearranged as needed to fit various environments and locations. This makes growing intuitive and efficient.
Step 11: Conclusion
In conclusion, this project demonstrates how thoughtful design can turn a short term necessity into a long term asset.
By transforming a market stand into a modular garden, we reduce waste, support local communities, and introduce more green space into urban environments.
I hope this instructable inspires others to rethink temporary structures and design with sustainability in mind.
