Introduction: STEM DIY Soldering Kit: LED Rotating Globe Planetary Project
The Flashing LED Globe DIY Kit adopts a PCB three-dimensional structure design combined with motor rotation and LED light flashing circuit.Built-in 3 music atautomatic looping playing mode if turn ON music play switch. Also can adjusting the rotational speed. It is a very interesting DIY electronic kit which enables users to learn soldering skills.
Feature:
【ROTATING PLANETS】The lights on the elliptical PCB board of the DIY soldering kit illuminate in turns, creating a rotating effect akin to small planets, which is quite captivating. The exquisite design of the white waterfall light, with its interplay of light and shadow, seems to narrate a fantastical journey through the universe. Paired with such a unique lighting fixture, it enhances the indoor decor ambiance, allowing one to experience the mystery and beauty of the cosmos.
【BRIGHTNESS ADJUSTABLE】DIY soldering practice kit comes with a circular PCB board equipped with a potentiometer, allowing you to adjust the brightness of the blue LED lights. You can customize the lighting to a comfortable level according to your preference. This is a fun and practical project, suitable for soldering enthusiasts to practice their soldering skills and understand circuit principles.
【SPEED SWITCH】The base of the DIY globe kit is equipped with a motor, allowing the globe to rotate 360 degrees, adding a futuristic touch to it. By controlling the motor switch, you can observe various aspects of the kit, as if being immersed in the universe. Whether as a learning tool or a decorative piece, this rotating globe is a creative and enjoyable choice.
【BUILT-IN THREE MUSICS】The planetary kit comes with three sci-fi-inspired music tracks, allowing you to immerse yourself in the wonderful spectacle of planets orbiting the Earth. The music playback adds dynamism and emotion to this planetary model, making observations more vivid. Equipped with separate control switches, you can freely choose to turn the music on or off, making the experience more personalized.
Step 1: Install 1pc SMD Components SOP-8KT148A Music IC at U1.
Please verify and confrm the installation direction of KT148A.
There is a dot mark on one end of the IC and there is a gap mark on PCB silk screen where the IC can place on. These two marks are corresponding to each other and are used to specify the installation direction of the IC.
Step 2: Randomly Choose a Pad on the PCB, and Then Melt the Solder
Step 3: Fix KT148A
Use a soldering iron to melt tin on the pad just now and hold KTi48A with tweezers in the other hand to place/press on U1 to prevent movement.
Take care to match and align each pads. Then remove soldering iron. Then remove tweezers aftersolder tin cooling and solidification.
Step 4: Connect Other Pads on KT148A by Tin and Soldering Iron
Step 5: Install 1pcs 47ohm Metal Film Resistor at R2
Step 6: Instal 2pcs 0.1UF 104 Ceramic Capacitor at C2,C3
Step 7: Fix 2pcs M3*10mm Screw With 2pcs Gasket and 2pcs Nut or Tin
Step 8: Install 1pcs 22uF 16V Electronic Capacitor at C1
Step 9: Install 1pc DC-005 Power Socket at DC_5V
Step 10: Install 1pc SS-12F44G5 Toggle Switch 1P2T at SW1, SW2
Step 11: Install 1pc 1K RV0931 B102K Potentiometer at R1
Step 12: Fix 1pc JS-30 DC Motor by 2pcs M3*10mm Screw and Nut.
Step 13: Cut and Reserve 4cm Wire From JS-30 DC Motor.
Step 14: Red Wire Connect to ‘motor+’ Pad and Black Wire Connect to ‘motor-’ Pad.
Step 15: Fix 4pcs M3*30mm Copper Pillar by 4pcs M3*5mm Screw.
Step 16: Tear Off the Protective Film on the Surface From Speaker.
Step 17: Stick the Speaker at the Position Shown in the Picture.
Step 18: Cut and Reserve 4cm Wire From Speaker.
Step 19: Red Wire Connect to ‘Beep+’ Pad and Black Wire Connect to ‘Beep-’ Pad
Step 20: Place 2pcs 0.4*4*10mm Metal Spring on M3*10mm Screw
Step 21: Install 1pc 10Kohm Metal Film Resistor at R4 on PCB HE007-D
Step 22: Install 1pc DIP-8 IC Socket at U2.
Step 23: Identify the Positive and Negative Lead of LED.
Step 24: Install 12pcs 3mm Blue LED on the Same Side Which Has Silk Screen Mark.
Step 25: Install 12pcs 3mm Blue LED on Another Side.
Step 26: Install 1pc 10Kohm 3362 Potentiometer at R3.
Step 27: Install 1pc DIP-8 STC8G1K17A MCU at U2.
Step 28: Install 24pcs 3mm White Led on Pcb HE007-E.
Step 29: Fix 4pcs M3*12mm Copper Pillar on PCB HE007-B by 4pcs M3*5mm Screw
Step 30: Fix PCB HE007-B on DC Motor by M3*5mm Screw
Step 31: Place Tin at 6 Pad As Shown on PCB HE007-C and HE007-D
Step 32: Splicing and Alignment PCB HE007-C and PCB HE007-D by Pad and Tin.
Note: "VDD" pad connect to VCC pads. Please ensure that the 2 pcbs are perpendicular to each other.
Step 33: Splicing and Alignment PCB HE007-E on PCB HE007-D by Pad and Tin.
Note: "GND" pad connect to GND pads. Please ensure that the 2 pcbs are perpendicular to each other.
Step 34: Fix PCB HE007-C on PCB HE007-B by 4pcs M3*5mm Screw
Step 35: Installation Finished and Video Demonstration
Complete your very own Globe Planetary Motion Rotating Universe Model and enjoy the mesmerizing effect. Simply plug in the USB cable and marvel at the artwork you've created! This kit is perfect for:
- Desk decoration
- STEM teaching
- Graduation design
- Practice for electronic enthusiasts
- Birthday gifts
- Home/family/ece projects
If you want to have a try, click here to get your rotate global universe from us ^0^
