Introduction: STLCC T-Shirt
I decided to make a STLCC T-shirt, I chose this because when looking on their website I didn’t find very many options— so I made one.
T-shirt
Heat press
Graphic printer
vinyl paper
Scissors/exacto knife
Cling transfer paper
Step 1: Create Your Design
First choose your design or create one on Adobe Fresco here is mine.
Step 2: Upload
When you have created your design save it to your camera roll or upload to computer. Go to Adobe Illustrator, click new project and then upload. Choose your design you uploaded and do the following bellow to make cut line.
Step 3: Adobe Illustrator Panel Opening
- Go to window - layers
- Go to window- pathfinder
- Go to window- swatch libraries - other libraries and load Roland Versaworks swatch libraries
Step 4: Duplicate Layer
Duplicate the layer
- in the layer panel you created hold and drag the layer until you see the plus in the bottom right to duplicate it.
Step 5: Lock Original Layer
Lock the original layer
- click the lock icon next to the original layer to locker it
- click eyeball icon to next to the original layer to hide it
Step 6: Image Trace
image trace
- select the and go to image trace dropdown in the control panel.
- choose Silhouettes
Step 7: Expand Image
expand the image
- click expand in the control panel to convert the traced image to vector paths
Step 8: Pathfinder Operations
pathfinder operations
- with traced image selected, go to the pathfinder panel
- click merge then unite
Step 9: Offset Path
- Go to object- path-offset path
- check preview and adjust the offset as needed ( 0 is recommended )
Step 10: Inner Image
- Select the inner image and press Ctrl+x to cut it
Step 11: Apply Cut Contour Swatch
- open the Roland Versaworks swatch panel. (Attached above)
- Click the magenta box (CutContour swatch)
Step 12: Adjust Fill and Stroke
- go to the top corner of the screen
- click the first infill box ad select none for color
- click the second (out fill) box and select magenta
Uncheck the lock and toggle the visibility (eyeball icon) of the original layer if needed
Step 13: Save As PDF
- go to file- save as
- choose PDF format and save your file
Step 14: Print!
- To print the vinyl drag and drop into open que A,B,C etc.
- Double click to open settings
layout- check scale/ size of design, enter the # of copies
Quality- check media type, color management properties or preset true run color
Cut controls put the check mark in the box for cut image boundary
close and print!!
Step 15: Transfer to T-shirt
Once your design is printed get the sticky cling paper and transfer the design to it (make sure to cut out everything), smooth out any air bubbles.
make sure your heat press is set to 300 degrees, don’t burn your self
lay down your shirt and center how you would like , apply the design with the transfer cling paper hold and lock heat press for 15 seconds lift and remove film.
Step 16: All Done!!
Your shirt is done! Congrats!!
