Introduction: STRAWBOTS: Tools
Until STRAWBOT kits go into production mode, you'll be making the pieces with good ol' hand tools. I'll leave it up to you to decide what cutting method you use. I believe that scissors and and exacto-knife should be on hand.
Punches are what allow straws and foam to come together and make STRAWBOTS. In the following steps I'll highlight your basic tool options when it comes to punches.
Step 1: Round Hole Punches
Your standard hole punch is ¼" in diameter. It is the cheapest, most readily available punch you can buy, and the most important punch when it comes to building STRAWBOTS.
If you're serious about building all of the current STRAWBOT models, you'll need to invest in a couple more round punches.
If you're serious about doing custom mods to your STRAWBOTS, with different diameter straws, you may want to purchase any other available diameter
A visit to Michael's Craft store should provide you with the basic round punches in different diameters, but you'll likely pay $10, rather than $2. The advantage to the more expensive punches that you get from the craft store is that they have a longer reach than a standard punch. This comes in handy for sure.
Step 2: Pattern Punches
Pattern punches will come in handy if you want to pursue some customization. The one punch that I still feel I've under-utilized it the:
*WARNING*
When you go to the store to buy punches, you'll see many amazing designs like this. Don't be fooled. I bought a couple of them and they will only cut paper. The opening is not wide enough to cut craft foam. So disappointed.
- ¼".rectangle punch (you'll notice that it's used for Harvey 2.0 on the the feet and the head)
*WARNING*
Step 3: Leather Punches
It's really hard to find punches in non standard sizes and it's also difficult to find a hand punch larger than ¼" in diameter. So.... for those special occasions, leather punches can and will come in handy.
An advantage of the hand held leather punch is that you'll have a lot of different diameter holes and you'll only have to pay for one punch. The only drawback is that your holes will no be as clean and quick to cut. The advantage of the hollow leather punch set is that you'll be able to punch holes up to ½" in diameter which will allow you to incorporate bubble tea straws into your designs. Again, the drawback is that punching holes with this type of set is a little slower than regular hand punches.
