Introduction: STYROFOAM HOT WIRE CUTTERS
In 2019 I plan to expand my gardening activities, and for this I am going to build several small greenhouses with styrofoam as part of the building materials. For this I need a way to cut styrofoam quickly and cleanly, that is where the hot knives come in. One is a stationary one with an adjustable guide that can cut pieces 11" wide and one is a handheld one. These are not my original designs, others have published this before, I am just adding to the pile of designs and builds.
Step 1:
PART 1 - The stationary knife
Picture one shows the original stationary knife built from PVC tubing. The PVC made it FLIMSY and the second picture shows the schematic. The third picture is the final design made from ALUMINUM . As can be seen from the second picture the parts used were as follows:
Electrical Parts
1 - 12V 3AMP center tapped transformer
1 - on/off switch
some nichrome wire
electrical wire, a a couple of marettes(electrical connectors)
1 power cord
NON ELECTRICAL
aluminum tubing
1 aluminum elbow
wood, a couple of brass bolts, spring, washers and nuts
Tools
Drill and drill bits
soldering iron
various tools as needed
I originally built the stationary knife from PVC tubing but changed the build to aluminum as the PVC even though 3/4" was not stiff enough and the cuts were not smooth
PART 2 - The handheld knife
Picture four shows the schematic diagram, five and six show the hand held knife. Picture five is of the knife being powered by a 7.5V DC 1A adapter, picture six is the final knife.
Electrical Parts
1- 24V AC 2A center tapped transformer
1 - dimmer switch
1- electrical cord
some nichrome strip
electrical wire
NON ELECTRICAL
PVC tubing
3/4" wooden dowel
piece of 3/4" copper pipe
Tools
Same as above
Step 2: Using the Knives
As I mentioned before I intend to build several small green houses using styrofoam. Picture one shows a styrofoam thing from some type of appliance. It is approximately 24"x24" square. 24" wide is OK but 24" deep is too much. The space available to me is 15" deep from the wall, it needs to be cut.
Pictures 1-4 show the results of cutting with the stationary knife. Results acceptable for first time use, the spring on the knife needs to be stiffer.
The hand held knife was made to remove the material as shown in pictures 5-8. As I was finishing item in picture 8 the power supply failed. As I was working in the garage with no heat my feet were freezing, so I cleaned up the garage and went inside to warm up and to figure out what to do next. Picture 9-10 is the final design.
The link goes to my google drive INSTRUCTABLES folder
https://drive.google.com/drive/folders/1gMif5DeDMKLO--5aqT1oMjbUodZCiPBi?usp=sharing
Step 3: Next Project in This Journey
I guess I will have to build a heater for the garage. It's getting too damn cold.
