Introduction: SUPER EASY PAPER ROSES
If you're in search of a simple craft, this is perfect for you! These paper flowers are not only quick and easy to create, but they also make a lovely and thoughtful gift. I truly hope that everyone who makes these flowers enjoys the process as much as I did!
Here are the supplies used for this project:
- Red cardstock paper
- Green construction paper
- Scissors
- Hot glue gun
- Pencil
- Ruler
Step 1: Measure Paper
1. Measure and mark a 5x5-inch square on red cardstock.
2. Draw a circle within the square. (It doesn't have to be perfect!)
Step 2: Cut Out Circle and Draw
- Cut out Circle
- Draw a spiral onto your circle until you reach the center
- Cut along the lines of the spiral
Step 3: Starting to Create the Flower
Starting at the point where you made your cut, carefully and firmly roll the paper up until you reach the very end..
Step 4: Securing the Flower
Add hot glue to the bottom center of the flower, then push down to ensure the flower is secure. Ta-da! You have completed the flower process of this project.
Step 5: Creating the Stem
- Roll a piece of green construction paper into a tight cone shape.
- Trim the stem to your desired length
- Hot glue along the edges of the paper to secure it.
- Make three minor cuts at the top of the stem to create a base.
Step 6: Adding It All Together
- Add glue to the bottom of the flower.
- Apply the base of the stem to the bottom of the flower.
- The flower is finished!
- Repeat this step multiple times if you want more flowers.
Step 7: All Done!
The flowers are all set and looking fantastic! 🌼 Pro Tip: Don’t forget to add some lush green leaves for that extra pop and dimension! Your arrangement will be even more eye-catching!
