Introduction: SUPER POWERFUL POCKET GUN!!!
This is one thing you have to carry on you at all times. Its easy to make and its small, compact, powerful, ultra lightweight and can shoot anything small enough to fit into its pouch making this and epic little buddy to keep in your pocket.
WARNING: THIS CAN BE DANGEROUS IF USED INCORRECTLY OR CARELESSLY AND I AM TAKING NO RESPONSIBILITY FOR ANY HARM OR DAMAGE CAUSED BY THIS.
Enjoy, be careful and don't forget to download the videos below and comment.
Step 1: What You Will Need for This Instructable
You will need:
- A Coke bottle
- Sellotape
- Scissors
- A craft knife
- A heavy duty and stretchy rubber glove
Step 2: Cutting the Bottle and Preparing It
To start with you will need to cut the top off the bottle about 2 centimeters below the lid (or you can just use the photos as a guide). Now unscrew the lid and carefully remove the little plastic ring which is normally below it. This will be used later on to help hold the glove finger on. Now its time to cut a finger off the glove. I generally recommend the three largest fingers and even maybe the little "pinkie" finger but the choice is really yours.
Step 3: Attaching the Glove Finger and Fastening It
Now you can slide the finger onto the bottle top making sure you pull it over the small ledge at the bottom (this will strengthen it)making sure the finger isn't on an angle (if it is it will destroy the accuracy). Once you have done that you can now slide the small plastic ring back into place and very tightly sellotape/duct tape the finger on.
If your wondering what to use for ammo well i used 8mm steel balls (slingshot ammo) and they were going through several layers of corrugated cardboard, leaving deep dents in walls, denting metal and shattering plastic and glass. But it can, like i said, shoot nearly anything that'll fit in its pouch nicely so use your imagination and ENJOY
