Introduction: SUPER SIMPLE BAZOOKA
heres a super simple bazooka that looks cool (to some degree), and launches objects...
Step 1: Gather Materials
for this project, you will need
1. PVC (any bore, 2 1/2- 3 feet long though)
2. duct tape
3. paper
4. screwdriver
5. hairspray
2. duct tape
3. paper
4. screwdriver
5. hairspray
Step 2: Cut Small Slit/hole
cut a small slit in the back of the pvc pipe.
Step 3: Water Bottle Cap
get the water bottle cap, and screwdriver. gently push the screwdriver into the middle of the cap until theres a nice small hole.
Step 4: Water Bottle Cap + PVC
ok, now put the cap loosely into the end where you cut the slit/ hole. not INTO the slit/hole. but in the opening. depending on your bore-size, it could be tight, or loose. secure the cap with ductape in the hole until nice, and tight.
Step 5: How to Fire.
ok, so if you followed the instructions correctly, you are ready to fire. get some flammable hairspray, and squirt 2-3 times into slit/hole for small bores, and 4-6 for larger ones. squirt into other end of pvc pipe.
tear/cut some paper so its a inch thick and 3-4 inches long. fold paper until it fits snuggly into slit/hole. lastly, get a foam/plastic object that isnt too small, but not to big. push it down, and get a lighter to light paper. aim quickly at target watch it fly!
if you did this correctly, you shoulld see some small flames/smoke come out the hole in the cap. this is good.
ps- spraying front of barrel is to lube it for the object, plus makes it look like the flash of a gun.
WARNING: NEVER AIM/FIRE THIS AT PEOPLE
