Introduction: Saeco Xelsis SM76** Hidden Beverages
The Saeco Xelsis Sm76xx series is the top of the line Super automatic, it was advertised with 15 beverages.
But this is in fact NOT TRUE. there are 6 hidden beverages {including 1 duplicate/Larger serving}
In this Guide i will show you how to access those Hidden beverages.
Please note that i will use the Online demo window to show the instructions more clearly.
Since its identical to the Display the Xelsis Sm76** uses.
Step 1: Step 1: Setup the Xelsis
Just like in the instructions Set the Saeco Xelsis to the preferred settings you want to use.
In this guide i will use the english Language as the main language.
Before trying any different beverages, please set the Grind settings to the preferred setting,
Since i cannot know what coffee the reader uses, i will not go deeper into this.
And it is not of importance for the Guide. since each person has a favorite coffee strength.
Step 2: Step 2. the Hidden Beverages {Deutche AT}
to access the Hidden beverages Please go back to the settings and select language.
Select Deutche {AT} and click on the yellow check-mark.
Press the drinks button to go back to the selection Menu
The "hidden" beverages in the Deutche {at} Language are:
> Verlängerter
> Melange
> Großer Brauner
> Kleiner Brauner
> Caffe Crema
Step 3: Step 2. the Hidden Beverages {Français}
Go down in the selection menu and select Français and click on the yellow check-mark. Press the drinks button to go back to the selection Menu The "hidden" beverage in the French Language is:
> Grand Creme
Step 4: Step 3 Returning to the "english" Language
To return back to the English language Please follow the following steps:
1 click on the settings menu
In the setting Menu please click on the Language icon
Select the Language of your choice.
In this guide its the english language.
Now you're back in the english Language window.
Step 5: After Word: Facts/usefull Information
The total list of all 22 beverages on the xelsis is:
English:
1 Espresso
2 Coffee
3 Cappuchino
4 Latte macchiato
5 Caffe latte
6 Flat white
7 Espresso lungo
8 Americano
9 Espresso macciato
10 Restretto
11 Espresso doppio {Duplicate of espresso, but a double serving}
12 Cafe au lait
13 Cofe Cortado
14 Milk Froth
15 Warm milk
16 Hot water
Deutche {at}
17 Verlängerter
18 Melange
19 Großer Brauner {duplicate of Kleiner Brauner but a larger serving}
20 Kleiner Brauner
21 Caffe Crema
French
22 Grand Creme
It is not possible to select a beverage from the French or Deutche {AT} language under any of the other language's, these beverages are specifically for those language's.
Some beverages are delectable under a different Language, but they are named different, but they are still the same beverage
It is not possible to add the Beverages from the Deutche {AT }language to the profile then change the language, and select it again, This will not work in the online demo tool this is a bug so you are able to select it there, but on the machine this will not work
