Introduction: Safe Box
This is what your finally result should be after putting it together and uploading the code.
Step 1: Things You Will Need.
Jumper Wires, 220 OHM resistor, 16x2 LCD Screen, Push Buttons, Servo Motor, Breadboard,Arduino Uno.
Step 2: Code
James chinchay
#include
#include #includeint address = 0; static unsigned long SaveTimer; static unsigned long SaveDelay = (30 * 1000);
char CODE[10] = "1234E"; char Str[10]; char CodeLength = 4; int Pos = 0; bool Unlocked; static unsigned long DisplayTimer; static unsigned long DisplayDelay = 200;
LiquidCrystal lcd(12, 11, 9, 8, 7, 6);
int buttonPin1 = 2; int buttonPin2 = 3; int buttonPin3 = 4; int buttonPin4 = 5;
int enterbutton = 10; int clearlockbutton = 13;
Servo myServo; //setting up the construct program void setup() {
myServo.attach(A1);
int EEPROMCodeOK = true; for (Pos = 0; Pos <= (CodeLength); Pos++) { Str[Pos] = EEPROM.read(Pos); if (!(strrchr("1123456789", Str[Pos]))) { // not a valid code EEPROMCodeOK = false; } } Pos++; Str[Pos] = EEPROM.read(Pos); if (Str[CodeLength + 1] != 'E') EEPROMCodeOK = false; if (EEPROMCodeOK) { Str[CodeLength + 2] = '\0'; strncpy(CODE, Str, CodeLength + 1); } ClearCode(); // setting up inputs pinMode(buttonPin1, INPUT_PULLUP); pinMode(buttonPin2, INPUT_PULLUP); pinMode(buttonPin3, INPUT_PULLUP); pinMode(buttonPin4, INPUT_PULLUP);
pinMode(enterbutton, INPUT_PULLUP); pinMode(clearlockbutton, INPUT_PULLUP);
lcd.begin(16, 2); lcd.setCursor(0, 0); //setting up messaged lcd.print("Hello Mr Birch"); delay(2000); lcd.clear(); lcd.setCursor(0, 0); //setting up prompt for password lcd.print("Password:");
DisplayTimer = millis() + 200; }
void loop() {
Lock();
Pos = constrain(Pos, 0, CodeLength); // read buttons int buttonState1 = digitalRead(buttonPin1); int buttonState2 = digitalRead(buttonPin2); int buttonState3 = digitalRead(buttonPin3); int buttonState4 = digitalRead(buttonPin4);
int clButtonState = digitalRead(clearlockbutton); int enterButtonState = digitalRead(enterbutton);
lcd.setCursor(9, 0); //requirements to activate if (buttonState1 == LOW) { Str[Pos] = '1'; Pos++; Str[Pos] = '\0'; delay(250); while (digitalRead(buttonPin1) == LOW);
else if (buttonState2 == LOW) { Str[Pos] = '2'; Pos++; Str[Pos] = '\0'; delay(250); while (digitalRead(buttonPin2) == LOW);
else if (buttonState3 == LOW) { Str[Pos] = '3'; Pos++; Str[Pos] = '\0'; delay(250); while (digitalRead(buttonPin3) == LOW); }
else if (buttonState4 == LOW) { Str[Pos] = '4'; Pos++; Str[Pos] = '\0'; delay(250); while (digitalRead(buttonPin4) == LOW);
} else if (enterButtonState == LOW) { Str[Pos] = 'E'; Pos++; Str[Pos] = '\0'; delay(250); while (digitalRead(buttonPin1) == LOW); if (strcmp (Str,CODE) == 0) { Unlocked = true; lcd.setCursor(0, 0); lcd.print(" Access Granted"); delay(2000); lcd.clear(); lcd.print(" Unlocked"); } else if (SaveTimer > millis() && (Pos + 1) == CodeLength) {
strcpy(CODE, Str); for (Pos = 0; Pos <= (CodeLength + 1); Pos++) { EEPROM.write(Pos, Str[Pos]); } lcd.setCursor(0, 0); lcd.print("Saving Code:"); lcd.setCursor(0, 1); lcd.print(Str);
Unlocked = true; }
else {
lcd.clear(); lcd.print(" Access Denied."); delay(2000); lcd.clear(); lcd.print("Password:");
} //unlocking code while (Unlocked) { Unlock(); if (digitalRead(clearlockbutton) == LOW) { delay(200); lcd.clear(); lcd.print(" Locked"); delay(2000); lcd.clear(); Unlocked = false; SaveTimer = millis() + 30000; } }
ClearCode();
else if (clButtonState == LOW) { delay(500);
while (clearlockbutton == LOW); if ((millis() - SaveTimer) > 4500) {
ClearCode();
if ( (long)( millis() - DisplayTimer ) >= 0) { DisplayTimer += DisplayDelay; lcd.setCursor(9, 0); lcd.print(Str); lcd.print(" ");
void ClearCode() {
Pos = 0; Str[Pos] = '\0'; lcd.setCursor(0, 0); lcd.print("Password:"); lcd.setCursor(0, 1); lcd.print(" ");
void Unlock() {
myServo.write(150);
} //program locking button void Lock() {
myServo.write(50);
Step 3:
when done everything it should look like this.
