Introduction: Safer UK Sonoff Wireless Switch- Home Automation.
I recently bought some Sonoff Wireless switches online and although I was pleased with the operation of these switches, I was not content with the way the wiring of mains voltage to and from these devices is made, not least the exclusion of the Earth wire as the Sonoff units only provide terminals for Live and Neutral.
I was wanting a safer way to wire these units in and was looking at project boxes when I hit on the idea of using a two way trailing socket to house the Sonoff and provide a designed safe enclosure while still allowing the functions of the Sonoff to be accessed.
These sockets allow them to be plugged into existing equipment without cutting into its wiring and can be moved as and when required.
Beware that this project involves wiring of mains voltage which should only be attempted by a suitable competent person and building and using the unit is at your own risk and I take no responsibility for any loss or injury in providing this educational information.
Step 1: Tools and Equipment Required.
- A trailing socket which may be dismantled- look for screw heads either on the front or rear of the socket. Note that some of these sockets do not have screws, but captive clips which prevent disassembly and these should be avoided.
- Mains plug and lead.
- A Sonoff Wireless Switch.
- Screwdriver to dismantle socket and screwdriver to wire the terminals.
- Sharp side cutters.
- Sharp knife
- Pliers
- Glue gun and glue
Step 2: Dismantle the Socket
This socket is ideal for the project and cost around £2.50 from national high street home store. Note the screws on the rear of the unit.
Step 3: Socket Connections
This is a typical layout of one of these sockets, with copper strips connecting the terminals to each of the pins. To make room for the Sonoff, the left hand connections and internal mouldings need to be removed.
Step 4: Copper Strips Trimmed to Size and Case Preparation.
I used my side cutters to trim down the copper strips, removed all redundant copper and then used the cutters again to remove the unwanted plastic from the base. The plastic flies off at all angles and at surprising speed, so wear eye protection. Once done, I removed MOST of the plastic material from the top cover, retaining that around one hole where the Sonoff reset switch will engage.
Step 5: Remove the Sonoff PCB From Its Case and Trial Fit in the Case.
The Sonoff case comes apart really easily, exposing the PCB. Place this into the base as shown and carefully fit the top to ensure there is enough room for the PCB, whilst ensuring the reset switch fits into the intended hole.
Step 6: Wire Up the Mains Cable to the Sonoff.
Using a mains cable, I wired this up as shown having confirmed Live and Neutral locations with the Sonoff original casing and ensuring each wire was routed in the safest manner within the socket itself.
Step 7: Reassemble and Test
Once the wiring is complete, refit the cover, ensuring the reset switch engages in its new hole once more and then screw the new Sonoff Socket together.
Plug in and switch on the unit and after a few seconds, its LED will illuminate to show that the project is working.
After unplugging, I filled the unused Earth and Live holes (excluding the reset hole, obviously) with hot melt glue from a glue gun to prevent any attempt to force a plug in there by accident.
It is now complete and ready to use!
10 Discussions
1 year ago
I had the same idea. This is my second sonoff controlled strip - this time I took a couple of photos.
I started with a pound-shop extension strip, worked out where to place the sonoff circuit and cut away the plastic so that it fitted. I kept the all important earth strap and was careful to keep the Live side switched and properly assigned to the correct sockets. (see internals photo). As for the cover I drilled two small holes to align with the press-switch and LED. I also filled the now unavailable plug holes with hot glue so that nobody pushed in a plug and broke it (see photo of finished item).
Reply 8 months ago
Please change the fuse to 5A for your safety.
Reply 8 months ago
Well said nmg196. I did, of course, and should have said. Like you already mention it will prevent someone overloading the little relay of the Sonoff.
8 months ago
If anyone builds this (or similar) please note the plug should be immediately swapped to a 5 amp fuse and definitely nothing higher. The Sonoff will quickly melt at 13A and potentially catch fire. A 5 amp fuse typically blows at 1.6x the rated value, so that should cause it to blow at 8amps and keep you safe from melting the Sonoff. This brand of device doesn't exactly have a high reputation for safety in the first place - google "sonoff melted" for more info. The only one I have in my house is now inside a fireproof metal case! (grounded)
2 years ago
It's hard to tell by your pictures, but have you tied neutral to ground in the extension socket?
I am by no means an expert, but I don't think that is particularly safe?
https://www.quora.com/Why-is-neutral-connected-to-...
https://www.reddit.com/r/AskEngineers/comments/38o...
Again I may be totally wrong, but it doesn't seem good to me and thought I would mention it just in case.
Reply 2 years ago
I'm not the author, but I'd say that he didn't do that - the earth wire is simply looping up behind the brown (live) connector in to its own connector.
3 years ago
This is great, do you think this can actually hand 10a? I assume you wouldn't put anything about 1.5kw into it?
Reply 3 years ago
The sonoff itself states it is rated at 10A which theoretically means it could handle 2.2kW. The socket itself is safe to 3kW. A look at my appliances shows i have nothing above 2kW and that is a kettle which would be operational for a maximum of around three minutes, so to answer your question, I personally would trust an appliance of 1.8kW.
3 years ago
I'm glad you could mod it the way you needed :)
Reply 3 years ago
Thanks Swansong. I do like the Sonoffs, but when I see some of the wiring on video channels, makes me shudder the lack of safety considerations. So I thought I would share what I made.
