Introduction: Saggy Freezer Shelves
Every time I opened the freezer door, I would be met with an avalanche of frozen, rock hard missiles.
For some unknown reason the front stays on the shelves no longer sit well within their plastic guides.
An extension of the powder coated wires needed to be made. Welding was not possible due to fumes from the powder coating and rust of the steel shelves.
The solution was short aluminum tubing extensions.
Step 1: The Lack of Tolerance
For some reason I am unable to add more than one photo per step tonight.
This shows how close the unladen shelf is to coming adrift
Step 2: Tools and Supplies Needed.
A length of aluminum tube that has an internal diameter to allow it to fit snuggly over the powder coated stay.
A pipe/ tube cutter.
A sharpie for marking (not shown below)
A vice. (Not shown, I never show off my vices:-) )
Step 3: Marking and Cutting
Align the tube beside the stay.
Adding the depth of the plastic channel mark for the centre of the cut.
Step 4: Cutting
Use the tube cutter to remove the extension from the main tube.
Some hints to make this easier :-
Hold the tube in a vise. It is important that the work does not turn.
Use something soft in the jaws of the vice to save marking the tube.
Only tighten the cutter a small amount each time.
Rotate the cutter toward the back rib of the tool as this makes scouring the tube easier.
Rotate the cutter until it turns freely.
Then tighten it a little. Repeat this until the extension piece comes off.
The trick is to work slowly.
Remove any burrs from the cut end.
Step 5: First Extension in Place
Slide the tube over the end of the stay.
Repeat the process until you have cut sufficient extensions for your shelves.
Step 6:
Place an extension on each end of each stay.
Step 7: Problem Solved
Carefully place shelf, with extensions, back in the freezer. You may need to jiggle the stays a little to ensure that they seat properly.
Overload the shelves as normal :-) and they stay on place.
Hooray! Problem solved.
MMmm A freezer is a big box, would I be too lateral to enter it in the box contest?
Nah!!!
2 Comments
10 years ago on Introduction
cool idea!
That's a great idea, I have that problem out here in my shop fridge!
