Introduction: Sampan Origami Boat - Small and Big
Making an origami sampan boat is easy enough as all you need is a square sheet of paper. Some years ago, I made one large enough to float in. A large square of paper was made from a newspaper reel of paper glued together. The square took up most of the living room. It was then folded into a sampan boat. This wasn't that ridged, so it was used as a template and layers of corrugated cardboard laid into it and glued together using PVA glue and clamps. The finished cardboard boat was inserted into a large plastic tube of building plastic and the ends secured. While it wasn't terribly fast in the water, it was a great way to relax and enjoy a beer. The finished boat was light and could just fit into a car.
This project demonstrates how the template can be made from a small sheet of square paper.
Three-inch square sheet of paper
Traditional Origami Sampan Instructions Step by Step - Origami Expressions
Step 1: Fold Corners Inwards
Make a crease in the paper from one corner to the other diagonally, both ways.
Fold and crease the corners into the center.
Step 2: Two Corners In, 2 Out
Fold two corners inside to the center and the other two outside.
Step 3: Fold Backwards
Turn it over and fold as shown.
Step 4: Corners Inwards
Fold the four corners inwards and crease down.
Step 5: Fold Inwards Again
Fold the same corners inwards again and then fold and crease the top and bottom to the center.
Step 6: Turn Inside Out
Holding the folds from the center, turn inside out.
Step 7: Sampan Completed
Shape the boat and its finished.
Step 8: Upscale
The boat can be upscaled to make it larger, used as a template for a corrugated cardboard boat and made waterproof by covering it with a large plastic tube of builder's plastic.
