Introduction: San Diego LDS Temple - Taito 3D Printing Services
3D Printed San Diego LDS Temple (with Lights)
LED - https://www.netram.co.za/led/9881-led-3mm-white-10-pack.html
Filamnet - https://www.3dprintingstore.co.za/boksburgstore/wanhao-pla-filament-1kg-1-75mm-white.html
Filament - https://www.3dprintingstore.co.za/boksburgstore/wanhao-pla-filament-1kg-1-75mm-transparent.html
SketchUp - https://www.sketchup.com/try-sketchup
Battery - https://www.diyelectronics.co.za/store/li-ion-li-po/2439-lipo-battery-37v-1200mah-1c-1cell.html
Battery Charger - https://www.diyelectronics.co.za/store/battery-charger/1195-1a-lithium-battery-charging-module-with-protection.html?search_query=battery+charger&results=77
Switch - https://www.robotics.org.za/SWITCH-88-LOC
Step 1:
I used SketchUp to design the file. The windows are made out of clear filament. I've grouped the windows together, so please explode them from the rest of the design.
Step 2:
The base of the model is attached to the rest of the model via a nut and bolt set (you can use a soldering iron as well). The bolt is attached to the model via a soldering iron (you can use glue if you wish, but it's risky).
Step 3:
Solder the battery the LEDs, the switch and the battery charging module to the circuit.
Step 4:
I used a soldering iron to attach the windows to the model (you can use glue if you see fit).
Step 5:
Final Images.
