Introduction: Santa Earrings
This is a pair of Santa earrings that I made to wear during the Holidays.
2 - French Hooks
2 - 22-ga. 2" Headpins
2 - 24-ga. 1" Headpins
2 - Red 12x8mm Glass Teardrops
2 - Clear 8mm Round Crystal Beads
2 - Glass White Pearl 8x3mm Rondelle Beads
2 - Glass White Pearl 4mm Round Beads
Step 1: Assemble Santa
On the 2" head pin, put the round clear bead, then the round pearl rondelle. Put the red teardrop last.
Step 2: Closed Loop
This is a very simple design. Making a closed loop is the only thing you need to know. Bend the head pin at a 90° angle above the red bead. Leave enough space to wrap the loop. Wrap the wire around the jaw of a round nose plier to form a loop. Connect the loop to the French Hook before you close the loop in the next step.
Step 3: Closing the Loop
Close the loop by wrapping the wire around the top of the wire above the bead, about 3 times. Trim the excess wire, and press the cut end against the loops.
Step 4: Santa Hat Dangle
String the round pearl on the 1" headpin. Bend the head pin at a 90° angle same as above. Leave enough space to wrap the loop. Form a loop with the round nose pliers. Connect to the loop above the Santa before finishing the wrap. As above wrap the wire about 3 times above the bead to finish the loop. Trim the excess wire, and press the cut end against the loops.
