Introduction: Santa's Sorting Hat With Micro:bit
About: I used to teach middle school science, but now I run my own online educational science website. I spend my days designing new projects for students and Makers to put together.
We've been working closely with Santa's Workshop to bring you another innovation in naughty or nice list communication. Now, you can check in real-time if your good and bad deeds have affected your standing on Santa's Naughty or Nice list! A fun project to make and share with your friends who's results may surprise you!
The hat consists of a servo, a micro:bit with a Crazy Circuits Bit Board, and a pushbutton. It's a pretty simple build overall and a real big hit with kids of all ages.
We've included a printable version (Easy) and an epic version with LEDs (Advanced). Make the project that's right for your skill level!
If you prefer a version of this product with an Arduino check out our Santa's Sorting Hat - Arduino Edition
Love Christmas? You might also like our "Circuit-Tree" Singing Christmas Tree project.
If you like our projects and want to see more of what we get up to each week please follow us on Twitter, Instagram, Facebook, and YouTube.
Brown Dog Gadgets does in fact sell kits and supplies, however you can most certainly build this project without buying a single thing from us. Though buying from us does help support small our small business and us building cool projects just like this.
Electronics Needed:
Craft Supplies Needed:
Optional: A Silhouette or Cricut electronic cutting machine to cut out the design
Step 1: Gather Materials
  • Gather the materials (and tools) you'll need for the project.
Step 2: Cut Foam Strips
  • Cut the foam strips to size.
  • For the hat that we used, we cut a 23-inch by 1.5-inch strip to go around the head and two 14-inch by 1.5-inch strips to go over the head in both directions. Measure your hat and head to find the right size for you.
Step 3: Connect the Foam Strips
  • Use rubber cement to connect the ends of the long strip to make a circle.
  • Connect the two shorter pieces to the main circle, making a dome shape as shown.
Step 4: Attach the Bit Board and Servo
  • Use a plastic-covered twist tie to attach the servo motor through the GND and 3V holes.
Step 5: Connect the Button
  • Wrap Maker Tape around the button, connecting it to itself as shown.
  • Add foam mounting tape to the back.
  • Adhere the button inside the hat where it touches the top of the head. This button will activate the code when the hat is placed on the wearer's head.
  • Adhere one of the strips of Maker Tape to Pin 5 and the other strip to GND.
Step 6: Connect the Servo and Battery
  • Connect the Servo to Pin 13 using the pins on the back of the Bit Board. The ground wire is the brown one.
  • Use foam mounting tape to secure the battery pack.
  • Secure the wires into the screw terminals with a small screwdriver.
Step 7: Connect the Stick
  • To make the arm that will swing the hat around, we put a dab of superglue to connect the LEGO to the popsicle stick (this is optional).
  • Then, we wrapped the two together with a piece of electric tape as shown.
Step 8: Add the Micro:bit and Code It
  • Place the micro:bit into the Bit Board and connect it to your computer to download this code.
  • Tip: Remove the stick from the motor during your first upload. Then, press button "B" to move the motor to the center position, and place the stick onto the motor facing straight up.
Step 9: Make the Topper
  • Using the foam template, cut two of the shapes out of foam.
  • Apply rubber cement to the edges, leaving the area at the bottom dry, as shown.
  • Press the two pieces together, then slide the popsicle stick between them. By keeping the glue away from the stick, you can insert it more or less to match the height of your Santa Hat.
Step 10: Fill the Santa Hat
  • Glue the foam inside the peak of the Santa hat with the front of the hat matching the front of the foam piece.
  • Insert the rest of the assembly inside the hat. It's easiest to do this in two steps: detach the foam piece and place it inside, then place the headpiece inside, then carefully re-attach the stick to the motorhead inside the hat.
Step 11: Test & Decorate (Simple Version)
  • Test the hat by placing it on your head - it should dance around!
  • To complete the simple version of the hat, print and cut out the template, then hot glue the pieces in place, as shown.
Step 12: Advanced Version: Let's Add LEDs!
  • For the advanced version, we'll make the template 3D and add lights!
  • Staple the template to a piece of cardboard. We removed one side of the cardboard to make it easier to punch.
  • Cut out the arrow shape and use a hole punch to punch out the holes.
Step 13: Add Craft Foam
  • Line the outer edge with .5 inch strips of craft foam. Cardboard strips would also work.
  • Paint the arrows green.
Step 14: Glue the Words
  • Glue the words behind the arrows, making sure not to cover the LED holes.
Step 15: Plan the LED Circuit
  • The circuit is a bit complex: We soldered two rows of 12 LEDs together so that the animation would be easy to code. See the diagram for details. Make two sets of 12, one set for each arrow. There are detailed soldering instructions in the next step.
  • In the second diagram, you can see the LED layout, with the LEDs closest to the Bit Board (#1) placed at the bottom of the arrow, and moving around the arrow on either side toward the tip (#12). One of the two rows will have an extra LED that you can cut off.
Step 16: Solder the LEDs
  • This step is very tricky! If you're new to soldering, partner with a maker with experience for this step.
  • The "fairy light style" NeoPixel LEDs are very tricky to work with because the wires are very thin and coated with resistive plastic. Use an X-ACTO blade to peel away the plastic, exposing the copper wire.
  • Add heat shrink tubing before connecting the wires to the long female jumper wires. This will make it easy to plug it into the Bit Board.
Step 17: Glue the LEDs in Place
  • Following the diagram in step 15, glue each LED in place behind each hole.
  • Remove any glue that makes its way to the front with tweezers.
Step 18: Glue the Arrows to the Hat
  • Connect the "Nice" arrow to Pin 0 and the "Naughty" arrow to Pin 1.
  • Use Hot Glue to glue the Arrows to the hat, with the "OR" sign in the center.
  • It's time to see who's NAUGHTY and who's NICE!
