Introduction: Saw Shaped Wrench
The following information is a single lesson in a larger Tinkercad project. Check out this and more projects on Tinkercad.
ln this lesson you will learn how to create a cool saw shaped wrench.
- Continue to the next step.
Step 1: Saw Shaped Wrench
- Start the lesson by dragging a polygon to the workplane.
Step 2: Saw Shaped Wrench
- Now, rotate it 30 degrees.
Step 3: Saw Shaped Wrench
- Hold the shift button and scale it smaller to a width of 14mm. Then to a height of 3mm. Remember you can adjust the "Snap Grid" located in the lower right corner of the editor from 1.0 to 0.1 for more control.
Step 4: Saw Shaped Wrench
- Move it to the area outlined in orange. Duplicate the shape in place by pressing CTRL+D on the keyboard.
Step 5: Saw Shaped Wrench
- Scale it bigger to the size of the area outlined in orange. Keep the shift button pressed while scaling! Be as accurate as you want.
Step 6: Saw Shaped Wrench
- Repeat the previous steps. CTRL+D, Move and scale it to the area outlined in orange.
Step 7: Saw Shaped Wrench
- Now, let's make the rest. CTRL+D, Move and scale it to the area outlined in orange.
Step 8: Saw Shaped Wrench
- Drag a Tube shape to the Workplane.
Step 9: Saw Shaped Wrench
- Scale the tube to the height of 2.5mm and size of 10x10mm.
Step 10: Saw Shaped Wrench
- Because its a tool, let's make it precise by aligning the shapes. Select all objects except the hole shape. Click the Align button on the menu bar. Now, align the shapes in the area outlined in orange.
Step 11: Saw Shaped Wrench
- You're almost done! Select all the objects. Group them together by clicking the group button on the toolbar.
Step 12: Congratulations!
You made it!
