Introduction: Sawdust Firestarters
I’ve seen posted a number of homemade fire starters since I have come to this site, and if there’s one that I find the most effective it’s got to be sawdust fire starters.
I used to make these sawdust fire starters as a kid after learning how to do it from of one of my friends dad.
They are so effective they’ll stay lit in rain (not torrential downpours), on top of snow, and in high winds so they’re perfect if you need to start a fire in moist conditions with less-optimal wood, and they’re super easy to make:
Ingredients required:
sawdust
tea candles
ice-cube tray
Step 1: Step 1: Melting the Wax
I find the best method for melting the wax with minimal wastage is to put them into a sauce pan and melt with that. You can use a non-stick one if you want, but it doesn't really matter, provided it heats up evenly to melt the wax.
Step 2: Step 2: Stuffing the Sawdust
What you want to do whilst the wax is melting is stuff the sawdust into the ice cube tray, but in such a way that it doesn't over flow, and is tightly packed. If it over flows to adjacent cubes, it may end up with 2 cubes stuck together.
Step 3: Step 3: the Melted Wax
At this stage, you have stuffed the sawdust into your ice cube tray, and the wax has melted. Carefully pour over the wax over the sawdust so that it can expand, but not over fill the tray, The sawdust will expand a fair bit so be careful.
Step 4: Step 4: Excess Wax
You should now pour off any excess wax that you have on the tray. This way you can use the scraps for later on and make more.
Step 5: Step 5: Freeze the Cubes
Now you have poured off the excess wax, you will want to freeze the cubes. This ensures the wax sets solidly, and that the cubes will remain firm at room temperature. They will pop out of the ice cube tray once cold.
Step 6: Step 6: Lighting the Cube
You are now ready to light the cubes. They burn for between 10 - 30 minutes a piece which is plenty of time to get a fire started using them. They are great in cold, damp and windy conditions as they burn hot, and they burn well.
I hope you enjoyed this instructable.
