Scare Your Friends With a Fake Error! Taken to a New Level of FUN
Introduction: Scare Your Friends With a Fake Error! Taken to a New Level of FUN
A big thanks to hikinotimasha for the first instructable. This is basically going to teach you how to make an adventure out of error messages.
Step 1: Set Up the Code
First, open Notepad (not Wordpad) and enter this into it
lol = msgbox ("TEXT GOES HERE" ,16, "TITLE GOES HERE")
Insert text into the "text goes here" area, and make sure you keep the quotation marks, otherwise it will not work properly.
Step 2: Do the Same
Do the same for the "enter title here" bar. This is the text that will appear at the top of the window.
Step 3: Save the File
Save the file.
Go to File-> Save, and set the save type to "all files"
Give it a name, and end the name with .vbs
Step 4: Test the File.
Now double click on the saved file. An error message with text should pop up.
If this appears (see main pic below), then drop me a comment with everything you typed, and I will try to help you.
Step 5: Adventure #1
I have made a few adventure messages out of this. Here is the first one.
lol = msgbox ("You are in a cave. There are three exits, called Abort, Retry, and Ignore. Choose one.",2, "Adventure")
if lol = 3 then msgbox "Oops, you died.""Bottomless Pit"
if lol = 5 then msgbox "Oops, you died.""Bear Attack"
if lol = 4 then msgbox "Good, you are out of the cave. You suddenly asplode. Way to go.",16,"Oopsie"
Step 6: Adventure #2
Here is the second adventure I made.
lol = msgbox ("System failed to explode. Continue?",2, "SYSTEM")
if lol = 3 then msgbox "Aborted.""Abort"
if lol = 4 then msgbox "Running 'detonator.exe', Please Wait..." "Error"
if lol = 5 then msgbox "Ignored.""Ignore"
lol = msgbox ("WARNING! INTERNAL TEMPERATURE TOO HIGH. Continue?",20, "WARNING")
if lol = 6 then msgbox "Overheating...""Warning"
if lol = 7 then msgbox "Exiting...""Exit"
lol = msgbox ("Failed to exit. Continue?",20, "Exiting...")
if lol = 6 then msgbox "Exit Sucessful""Sucess"
if lol = 7 then msgbox "Window has asploded.""Go Boom."
Step 7: To Get Multiple Choice...
To get a multiple choice error message, just enter
lol = msgbox ("Text Here.",2, "Title")
if lol = 3 then msgbox "Text Here.""Title"
if lol = 5 then msgbox "Text Here.""Title"
if lol = 4 then msgbox "Text Here",16,"Title"
Or, for just a yes and no choice, then enter
lol = msgbox ("Text Here",20, "Title")
if lol = 6 then msgbox "Text Here""Title"
if lol = 7 then msgbox "Text Here""Title"
Be the First to Share
    • Toys and Games Contest
    • Home Improvement Contest
    • Art Challenge
      Art Challenge
    35 Comments
    YaroslavD
    YaroslavD
    6 years ago
    Is there a way of doing it so you can't close it? I mean how do you do it that the 'X' at the top is grey?
    LeytendoB
    LeytendoB
    Reply 3 years ago
    X=Msgbox("message",0+4096,"title")
    X=msgbox("You are in a cave. There are three exits, called Abort, Retry, and Ignore.Choose one.",2,"adventure")
    4=msgbox("oops you died",3,"Bottomless Pit")
    5=msgbox("oops you died",5,"
    bear attack")
    4=msgbox("good you are out of the cave. You suddenly asplode. Way to go.",3,"Oopsie")
    and
    lol = 3 msgbox "Aborted.""Abort"
    lol = 4 msgbox "Running 'detonator.exe', Please Wait..." "Error"
    lol = 5 msgbox "Ignored.""Ignore"
    if lol = 6 msgbox "Overheating...""Warning"
    if lol = 7 msgbox "Exiting...""Exit"
    lol = 6 msgbox "Exit Sucessful""Sucess"
    lol = 7 msgbox "Window has asploded.""Go Boom."
    trappokemon101
    trappokemon101
    5 years ago
    i have windows 10 so it does not put every thing i save on desk top screen it just has in file and opens what i put in notepad so i cant test it.
    maartenr
    maartenr
    7 years ago on Introduction
    x =msgbox("Bring me a shrubbery",4+64,"We are the knights who say NI")
    if x = 3 then msgbox "THEN... Then, when you have found the shrubbery,
    you must place it here, beside this shrubbery, only slightly
    higher, so we get the two-level effect with a little path
    running down the middle.""Firstly, you must find.... ANOTHER SHRUBBERY"
    if x = 4 then msgbox " Ni! Ni! Ni! Ni! "" Ow! Ow!"
    but it doesn't work :(
    sicknecro
    sicknecro
    13 years ago on Step 4
    x=msgbox("Fatal error, User Has Begun Encryption Process, Hard Drive will be Erased!",16"User Error")
    help please my daughter thinks she knows all about computers time to put her in her place
    jekabs.galins
    jekabs.galins
    x=msgbox("Fatal error, User Has Begun Encryption Process, Hard Drive will be Erased!",16,"User Error") - This shall work :) (You forgot a comma)
    michaelb958
    michaelb958
    Reply 11 years ago on Introduction
    Try this VBScript:
    do
    x = msgbox("Fatal error, User Has Begun Encryption Process, Hard Drive will be Erased!", 4096+16, "User Error")
    loop
    An always-on-top message that never goes away... Put it in Startup... BWAHAHAHAHAHA...
    jekabs.galins
    Here's a code for programming SIRI! (does commands like youtube, hi, minecraft, google)
    Set Sapi = Wscript.CreateObject("SAPI.SpVoice")
    set wshshell = wscript.CreateObject("wscript.shell")
    dim Input
    Input=inputbox ("Please type, what you want to open.")
    if Input = "minecraft" OR Input = "Minecraft"then
    Sapi.speak "Opening minecraft"
    wshshell.run "www.minecraft.net"
    else
    if Input = "google" OR Input = "Google" then
    Sapi.speak "Opening google"
    wshshell.run "www.google.com"
    else
    if Input = "youtube" OR Input = "Youtube" then
    Sapi.speak "Opening Y outube"
    wshshell.run "www.youtube.com"
    else
    if Input = "Hi, Siri" OR Input = "hi, siri" OR Input = "Hi, siri" OR Input = "hi, Siri" OR Input = "Hi" OR Input = "hi" then
    Sapi.speak "Hello there?"
    else if Input = "" then
    Sapi.speak "I did not understand you!, please try again?"
    else if Input = "LOL" OR Input = "lol" OR Input = "Lol" then
    Sapi.speak ",ERROR?"
    x=msgbox("ERROR","20","Err")
    else
    if Input = "tvnet" OR Input = "TVnet" then
    Sapi.speak "Opening TV Net"
    wshshell.run "www.tvnet.lv"
    end if
    end if
    end if
    end if
    end if
    end if
    end if
    iman4
    iman4
    8 years ago on Step 7
    Nice. Sometimes simple is the best.
    wesie42
    wesie42
    14 years ago on Step 4
    lol = msgbox("system failed to explode. Continue?",2,"SYSTEM"
    iflol = 3 then msgbox"Aborted.""abort"
    iflol = 4 then msgbox"running 'detonator.exe',Please Wait...""Error
    iflol = 5 then msgbox"ignored""ignore"
    lol = msgbox(WARNING!!INTERNAL TEMPERATURE TOO HIGH.Continue?",20,"WARNING")
    iflol = 6 then msgbox"overheating...""Warning"
    iflol = 7 then msgbox"exiting...""Exit"
    lol = msgbox("Failed to exit. Continue?,20,"Exiting...")
    iflol = 6 then msgbox"Exit sucessful""sucess"
    michaelb958
    michaelb958
    The small version:
    MsgBox "System failed to explode. Continue?", 4096+16, "SYSTEM"
    There's only an OK button!
    xproplayer
    xproplayer
    14 years ago on Introduction
    will someone please make me a story with 30+ popups for school im desperate here
    QwertyuioLP
    QwertyuioLP
    Reply 13 years ago on Introduction
    You could always try looping it infinite pop ups. Or for every one have an answer which has an answer and so on
    lol=msgbox("Do you want Windows to format your Hard Drive?",20,"Windows One Care")
    if lol=6 then msgbox "Why would you want that? Oh well. You asked for it...",6,"Windows One Care"
    if lol=7 then msgbox "Too Bad!",6,"Windows One Care"
    lol=msgbox("Formatting Hard Disk. Please Wait...",6,"Windows One Care")
    lol=msgbox("Formatting almost complete! One problem though. We need you to choose an answer from the list below.",2,"Windows One Care")
    if lol=3 then msgbox "You can't abort a formating! Try again.",6,"Windows One Care"
    if lol=5 then msgbox "You can't ignore the Format Wizard! Try again.",6,"Windows One Care"
    ccd=msgbox("Formatting almost complete! One problem though. We need you to choose an answer from the list below.",2,"Windows One Care")
    if ccd=4 then msgbox "Restarting Format! Please Wait...",6,"Windows One Care"
    lol=msgbox("Format Complete! Have a nice day!",6,"Windows One Care")
    hahahah this is by far the funniest thing i will have done to mess with my dad on the comp. the last thing i did was the whole desktop screen shot, remove icons thing.
    heres my adventure:
    lunchboxslayer27
    lunchboxslayer27
    o nvm, it got messed up wen i copy/pasted it. see if you could figure out how to fix it!
