Introduction: Scary Skull Lamp
I'm going to show you how to make a versitile skull lamp.
It utilises a usb led wire string, thus can use a number of power sources allowing it to be used in your car, at your computer, as a tree topper, or as part of a halloween costume.
Step 1: Components and Tools
For this lamp you will need:
Plastic skull (obviously!)
USB led string lights, wire type
Power source (mains or power cell)
Drill
3mm drill bit
Step 2: Construction
Drill a 3mm hole at the rear of the skull,
Unwind the led string.
Feed into the hole you have just drilled, the leds will be a tight fit, being the wire type they hold postion in the skull, and not drop to the bottom. This gives a better spread of light.
By using such a small hole when you get to the end of the lights the sleeve should be a tight fit and not need gluing.
All you need now is to connect the usb plug into your chosen power supply and switch on,
Step 3: In Use
As I chose to use a usb powered string light, it has created a versitile lamp that can be used in many scenarios, table lamp, as part of a costume, in your car, on your bike.
The use of leds has created a lamp which remains cool, I've run one of these lamps for a year without it feeling warm.
