Introduction: Schedule a Roomba (with Arduino)
We're the happy owners of a Roomba 620.
It's really doing a great job, but a scheduling feature is lacking, which means that we always had to trigger the cleaning process manually.
Fortunately, the iRobot Open Interface allows for easy programming. There are numerous ways of communicating with a Roomba. Here, we'll be using an Arduino, which is probably the easiest / cheapest way to do it.
Basically, the Arduino will act as a bridge between the computer and the robot, allowing us to send scheduling commands.
Step 1: What You Need
- A Roomba (I am using a 600 series model)
- An Arduino Uno and its USB cable (any other model should do the job as well)
- A computer
- 4 wires
And that's it.
Step 2: Remove Roomba's Cover
The Open Interface port should now be visible.
Step 3: Plug!
Using the wires, connect the Arduino to the Roomba as follows:
Roomba port 7 (GND) <-> Arduino GND
Roomba port 3 (RXD) <-> Arduino D4
Roomba port 4 (TXD) <-> Arduino D3
Roomba port 5 (BRC) <-> Arduino D5
The ground (GND) should be connected first and disconnected last, it's safer (for the Arduino).
Note: Don't connect the Roomba ports 1-2 to the Arduino, their voltage might damage your board!
Step 4: Programming Time
Connect the USB cable between the Arduino and the computer.
Start the Arduino software (freely available here).
Set the port using the menu Tools > Port > Arduino Uno (or whichever board you're using).
Open the serial monitor and select 19200 bauds.
Copy the following program:
// Roomba Scheduler
// Roomba port 7 (GND) onto Arduino GND
// Roomba port 3 (RXD) onto Arduino D4
// Roomba port 4 (TXD) onto Arduino D3
// Roomba port 5 (BRC) onto Arduino D5
#include <SoftwareSerial.h>
int rxPin = 3 ;
int txPin = 4 ;
int ddPin = 5 ;
int ledPin = 13 ;
SoftwareSerial Roomba(rxPin, txPin) ;
void setup()
// Arduino pins setup
pinMode(ddPin, OUTPUT) ;
pinMode(ledPin, OUTPUT) ;
digitalWrite(ledPin, HIGH) ;
digitalWrite(ddPin, LOW) ;
delay(2000) ;
// Changing Roomba baud rate to 19200
digitalWrite(ddPin, HIGH) ;
delay(100) ;
delay(200) ;
delay(100) ;
delay(200) ;
delay(100) ;
delay(200) ;
delay(100) ;
// Serial communication setup
Serial.begin(19200) ;
Roomba.begin(19200) ;
// Roomba Open Interface setup
Serial.println("Roomba Open Interface setup...") ;
delay (1000) ;
Roomba.write(128) ; // START
delay(150) ;
Serial.println("Sending Safe Mode command...") ;
delay (1000) ;
Roomba.write(131) ; // CONTROL
delay(150) ;
digitalWrite(ledPin, LOW) ;
delay (500) ;
// Sing a song
sing() ;
// Set current time
setCurrentTime(2, 13, 42) ;
// Set schedule
setSchedule() ;
// Finishing
Serial.println("Roomba Open Interface stopping...") ;
Roomba.write((byte)173) ; // Stop the OI
Serial.println ("All Done Baby!") ;
void loop()
void sing ()
Serial.println("Singing...") ;
Roomba.write((byte)140) ;
Roomba.write((byte)0) ;
Roomba.write((byte)7) ;
delay(500) ;
Roomba.write((byte)76) ;
Roomba.write((byte)16) ;
Roomba.write((byte)32) ;
Roomba.write((byte)79) ;
Roomba.write((byte)77) ;
Roomba.write((byte)74) ;
Roomba.write((byte)72) ;
delay(500) ;
Roomba.write((byte)141) ;
delay(50) ;
delay(50) ;
delay(500) ;
Serial.println("Singing [OK]") ;
void setCurrentTime (int aDayOfWeek, int anHourCount, int aMinuteCount)
Serial.println("Setting current time...") ;
Roomba.write((byte)168) ; // Command code
Roomba.write((byte)aDayOfWeek) ; // Day (0: Sunday, 1: Monday, 2:Tuesday, 3:Wednesday, 4: Thursday, 5: Friday, 6: Saturday)
Roomba.write((byte)anHourCount) ; // Hour
Roomba.write((byte)aMinuteCount) ; // Minute
delay(500) ;
Serial.println("Setting current time [OK]") ;
void setSchedule ()
Serial.println("Setting schedule...") ;
Roomba.write((byte)167) ; // Command code
Roomba.write((byte)127) ; // Days (127 (dec) = 01111111 (binary) = 0(Sat)(Fri)(Thu)(Wed)(Tue)(Mon)(Sun) -> schedule everyday)
Roomba.write((byte)16) ; // Sunday Hour
Roomba.write((byte)45) ; // Sunday Minute
Roomba.write((byte)15) ; // Monday Hour
Roomba.write((byte)0) ; // Monday Minute
Roomba.write((byte)15) ; // Tuesday Hour
Roomba.write((byte)0) ; // Tuesday Minute
Roomba.write((byte)15) ; // Wednesday Hour
Roomba.write((byte)0) ; // Wednesday Minute
Roomba.write((byte)15) ; // Thursday Hour
Roomba.write((byte)0) ; // Thursday Minute
Roomba.write((byte)15) ; // Friday Hour
Roomba.write((byte)0) ; // Friday Minute
Roomba.write((byte)15) ; // Saturday Hour
Roomba.write((byte)0) ; // Saturday Minute
delay(500) ;
Serial.println("Setting schedule [OK]") ;
Step 5: Adjust Your Parameters
You have to adjust the following parameters in the code:
Set the current time: (Day, Hour, Minute)
Set the desired schedule:
Roomba.write((byte)127) ; // Days (127 (decimal) = 1111111 (binary) = (Sat)(Fri)(Thu)(Wed)(Tue)(Mon)(Sun) -> schedule everyday)
Step 6: Let's Go!
Click the arrow button to execute your program.
It should take a couple of seconds. Check the monitor, the following text should appear:
Singing...
Singing [OK]
Setting schedule...
All Done Baby!
If everything goes smooth, Roomba will sing a cool song.
You're done! Just unplug and put the lid back.
Congrats!
