Introduction: Science in a Bottle: Water Whirlpools
Courtesy of wikipedia.org
The behavior of water and air can depend not only on factors like pressure and weight, but also motion. This nifty demonstration recycles used plastic bottles to show basic physics concepts in an exciting and interesting way.
Here's what you'll need:
Two plastic water bottles
Waterproof tape
One washer (that fits the bottle-lids snugly)
Stopwatch
Step 1: Start Recyling!
First, grab a pair (or more!) of clear empty plastic bottles of the same size.
Step 2: Half-Full
Fill one of the bottles with water.
Step 3: Already Empty
With your stopwatch ready, pour out the full bottle. Record how long it takes to drain with its "glug glug" method.
Step 4: Get Crafty
Place the washer on top of the refilled bottle. Hold the empty bottle on top of the washer and tape the setup together securely (this section has to be water-tight, this is where the vortex will be formed)!
Step 5: Swirl of Science
Get your stopwatch ready, you'll want to catch these times.
Flip the filled bottle so it is on top, give the setup a good swirl, and watch the water whirl!
It may take a few tries to get the hang of how much to swirl the water; don't be discouraged.
Step 6: Learning Why
Gravity is pulling the water down, but giving the water that initial swirl starts a spiralling drainage pattern, the same effect seen when cold air falls in a swirl as warm air rises (as in a tornado!).
The reason this drains faster is because, if you look close, you can see that throughout the whole process there is a hole where the air can flow up, surrounded by draining water. This makes for a much faster drainage than the traditional glug-glug of pouring from bottles. The glug-glug comes from the water and air having to both use the same passage; when the air is rising, the water ceases flowing and vice versa. This makes for slower drainage than the continuous vortex.
