Introduction: Screaming Trees: Birdhouse
Screaming trees, giving trees a voice. At Havas we have developed a self-sufficient chainsaw-detecting device, which is mounted on tree trunks. Via a built in microphone, it infallibly detects chainsaws within a 20 meter-area and sends out a warning signal if the tree is about to get cut down.
We decided to open this project to everyone that feels like it can make a difference in their own neck of their wood. Now you too can build your own laser cut birdhouse.
Step 1: NEEDED MATERIALS
• Laser cutter
• 3d Printer
• PLA filament (ABS is advised)
• MDF or your preferred material
• 8mm x 10mm screws + fasteners
• Hotglue gun + refill
• Spray paint (color is up to you)
• Tree hooks
Step 2: STEP 2
Assemble all laser cut parts, 3D printed
pieces and miscellaneous components.
Step 3: STEP 3
Take the front panel and insert the 3D printed perch into it. Keep it in place by using the lock part.
Step 4: STEP 4
Fold the birdhouse in a form of a triangle and lock the upper part with the screws and fasteners.
Step 5: STEP 5
Insert the front panel starting from the bottom.
Step 6: STEP 6
Insert the 3D printed roof, starting from the bottom and press it firmly in place.
Step 7: STEP 7
Insert the back panel starting from the bottom.
Step 8: DONE
By using hooks, you can now easily attach your Screaming Trees to a tree near you.
Step 9: THANK YOU
Please visit Screaming Trees for more information about the Screaming Trees Project.
Screaming Trees is a project from Havas GmbH.
