Introduction: Screen Saver Wallpaper on a Mac
in this Instructable, i will show you how to give your mac a screensaver instead of a wallpaper.
Step 1: Setup
first, you go to Finder>applications>utilities>terminal. once you have a terminal window open, go back to finder WITHOUT CLOSING THE WINDOW and open system preferences and set your screensaver to the one that you want on your desktop.
Step 2: The Hack
this is what you need to type in the terminal box:
/System/Library/Frameworks/ScreenSaver.framework/Resources/ScreenSaverEngine.app/Contents/MacOS/ScreenSaverEngine -background
i suggest just copy and pasting it.
Step 3: Step 3
actually there is no step 3. all i wanted to do here is ask for your vote in the hacks contest. Much appreciated are subscribers, also. im just sayin
Hack It! Challenge
9 years ago on Introduction
to make it so that it runs in the background, you can make a shell script file and use the nohup command. then, you will still be able to use terminal, or be able to close out of it.
in terminal type:
cd Desktop
nano (whatever filename you want).sh
on the new screen, copy paste the code...
then, press command x --> y --> enter
then type:
nohup sh (whatever filename you used).sh >/dev/null &
That should do it..
Very cool trick though!
