Introduction: DIY Screen Printing: Easy, Detailed & Inexpensive!
You can make your own unique, detailed, screen-printed shirt at home with a few simple materials! This method uses Drawing Fluid and Screen Filler to easily create your detailed design on a screen. There are other cheap methods you can use for screen-printing, however I really like this method because it allows you to create more detailed designs than you would using Mod Podge to paint on a screen and it's much easier than using an exacto knife to cut out fine details from contact paper. Also, it's less expensive than purchasing screen-printing frames from art stores, which are usually $15 & up.
If you'd like to see some finished products or view my other tutorials, check out my etsy shop & blog , or follow me on twitter ! Also, your constructive feedback on this tutorial is greatly appreciated! Thanks for looking and message me with any questions!
http://www.etsy.com/shop/anotherwaydesigns
http://anotherwaydesigns.blogspot.com/
http://twitter.com/anotherwaydsgn
Step 1: Materials
You need a few inexpensive materials which can be found at art stores & most craft stores.
- embroidery hoop (only about $2 for a basic hoop, available at craft stores)
- mesh material (nylon, polyester, silk - something with tiny holes that can serve as a fine screen)
- Drawing Fluid (I use Speedball, available at most art stores)
- small paintbrush
- newspaper
- Screen Filler (I use Speedball, available at most art stores)
- plastic spoon
- screenprinting ink
- squeegie
- shirt or bag to print on
Step 2: Assemble Your Screen
Take your mesh material and place inside embroidery hoop. Tighten hoop. Stretch material evenly across hoop and tighten hoop again. Should be tight or your material will shift and you won't have a clear print.
Step 3: Draw Your Design!
This is the fun part! Flip hoop over so that the screen is facing up. Shake your Drawing Fluid bottle. Using your paintbrush and drawing fluid, draw a design onto screen. (This Drawing Fluid will be washed out later after the Screen Filler is applied.) Make sure your brush strokes aren't TOO thin or the design will not be clear. Allow to dry fully (about an hour, or if you're impatient, speed the process along w/ your hairdryer)
*If you would like to be more careful when drawing your design onto the screen, you can draw your design onto paper using a marker first, then tape drawing to underside of screen and trace the design with drawing fluid.
Step 4: Apply Screen Filler
Place newspaper under screen to avoid making a mess. Shake your Screen Filler bottle. Spoon a couple tablespoons of Screen Filler onto top of screen (same side as the Drawing Fluid). Using squeegie, drag Screen Filler at a 45 degree angle from top to bottom of screen. Repeat a few times (2-4x) until you cover the whole screen. Do NOT do this more than a few times because it will become difficult to wash out the Drawing Fluid. (This Screen Filler will remain on the screen, and the Drawing Fluid will later be washed out.) Check the underside of the screen to make sure the Screen Filler isn't seeping through. If it is, don't worry, just use your squeegie to scrape off excess Screen Filler. (And next time, use a finer mesh material with smaller holes).
Allow to dry fully for a few hours or overnight (again, impatient folks can bust out the hairdryer). Should be completely dry to touch.
Step 5: Rinse Out Drawing Fluid
When screen is dry, rinse screen w/ water (use shower head if possible) to remove drawing fluid from screen. (This is where the ink will pass through the screen to create your image on your shirt or bag.) The Screen Filler should remain on the screen. It will block ink from passing through the areas that are not part of your drawing/design. Allow to fully dry again!
Step 6: Test Your Screenprint
Place your screen onto test paper/material and place a few spoonfuls of screen-printing ink onto the top of your screen. Hold screen down firmly in place with one hand. Using pressure with the other hand, drag squeegie at a 45 degree angle across screen to distribute the ink. Flip squeegie over and drag squeegie upwards. Do this about 3 times. Once you have made a satisfactory test print...
Step 7: Screenprint!
Print on a t-shirt, tote bag, pillow case, cardstock..anywhere! Have fun with different ink colors, too! You can print for around 15-20 minutes at a time, making sure the ink doesn't dry in the screen by "flooding" the screen between prints. To flood the screen, drag ink across screen using your squeegie WITHOUT applying pressure. This will distribute ink into the screen holes so the ink doesn't dry up too quickly.To clean up, simply scrape excess ink off screen with squeegie and rinse screen. Let screen dry and reuse later! You may have to stretch and tighten screen across embroidery hoop before your next printing session.
Let me know if you have any questions or comments. If you'd like to check out my etsy store or blog, please do... I love visitors!
53 Comments
3 years ago
Thank you - Awesome!!
5 years ago
I'm wondering if I didn't let my drawing fluid dry long enough or if I didn't put enough coats on. When I applied the filler fluid I'm pretty sure it wiped away the drawing fluid :/. I tried letting it dry overnight hoping that it would turn out, but no screen filler is leaving.
I love this tutorial and bought the supplies to make this years ago and I'm finally getting around to it. Thank you for posting!
Reply 5 years ago
Hi Mary! Perhaps there wasn't enough drawing fluid. Try layering more coats on, especially in spots where the drawing fluid looks thin, and let it dry completely. Best of luck!
8 years ago on Introduction
This looks like a great idea! I was wondering if it is possible to remove the mesh from the hoop, after the screen filler has been applied, but before printing the design? I'm hoping to do this activity with a number of students and we would need to share the hoops - would the image be damaged if it was switched between hoops over a couple of days before finishing printing?
9 years ago on Introduction
Very easy to understand, this is awesome.Good work.
11 years ago on Introduction
What do you recommend for cleaning the screen after? I know for a fact that Screen filler is really hard to clean out....
Since I spent 3 hours lettering and the screen filler just washed 1/4 of it away, I would like to know this answer as well.
Five Important Notes for printing with fabric inks:
http://www.speedballart.com/our-products.php?cat=21
10 years ago on Introduction
Very clever reversing the process!
10 years ago on Step 7
This is fabulous! Very clear and easy to understand - thank you!
hi! i just wanted to let you know that because i like this instructable so much, i have added it to my silkscreen guide... https://www.instructables.com/id/silkscreen-printing-easy-and-cheap/
thanks for sharing your ideas!
11 years ago on Step 7
Very helpful! and easy to understand, thanks a lot ! :)
12 years ago on Introduction
I had no idea it could be THAT easy! Screen printing has always seemed like some mystical and expensive process.
I've got a kit. I'm giving it a shot.
I left a comment about a year ago that I was going to try this with summer camp kids...I did, and they loved it! They drew their designs on the screen fabric (some traced computer-printed stencils) and painted the drawing fluid by themselves, and even put the screen filler over it without help. We used small hard plastic cards (like credit card slugs) to put the screenprinting ink on, which worked beautifully. I'm doing it again this summer--we have lots of materials left over.
Plus I got to make myself some shirts with the kids' designs, which were very cute and funny! Thanks again for the instructable.
12 years ago on Step 6
You can make a DIY rectangular screen too. go to Ross or Ikea and buy the cheapest wood rectangular photo frame that has no embelishments on the front. remove the glass and backing. stretch the screen/mesh fabric over the bare rectangular screen and use a staple gun to secure in place on the edges of the frame (do not staple on the side that will lay flat when you screen print). cover with duct tape before beginning the drawing fluid step.
12 years ago on Step 7
I want to screen print a pair of tights. Is this possible with this method?
Reply 12 years ago on Introduction
Indeed it is! They just need to be stretched out to the full extent while you're printing.
13 years ago on Step 6
hi, i am just getting into this, so you are using a smaller squeegie than you print, which i guess means you have to pull ink a few times... so how do you stop it from bleeding.
i have had results bleed or some areas not have ink even with a squeegie that is bigger than my printing area??
also i have a screen but there seems to be a lot of instructions that say i have to tape the edges?? can i skip that? it looks like you get around it.
can't wait for the reply, i have been put off trying again as my first to printing attempts have not worked (one invovling cleaning filler out, so i am going to read over your steps for that too)
thanks
Reply 13 years ago on Step 6
hi! since the frame is round, i use a smaller squeegie to make it easier. i usually only pull ink 3-4 times and if the screen is tight, and the ink is not runny, it shouldn't bleed.
also, since the screen is round, i didn't tape it. i do tape screens when i buy rectangular screens. if you have the $, i'd buy a screen from the store since they are stronger and tighter; if not, then this is a good cheap alternative.
