Introduction: Screw and Bolt Toy
This Instructables will show you how to make a screw and a bolt toy.
Step 1:
Start with a 25 mm cylinder.
Step 2:
Next you want to put a 22 mm wide cylinder in the 25 mm wide cylinder. The 22 mm wide cylinder will be longer then the 25 mm wide cylinder. Your design should start to look like a screw.
Step 3:
You then want to select the 22 mm wide cylinder and hit the thread button.
Step 4:
We are going to make the bolt now. Start with a 25 mm cylinder. This cylinder should be the same size at the one we started with before.
Step 5:
You want to then put a 22 mm cylinder inside the 25 mm cylinder you just made. Hit the thread button on and select the 22 mm cylinder.
Step 6:
You want to cut the threaded 22 mm cylinder from the 25 mm cylinder. This will make it so that there are threads inside the 25 mm cylinder.
