Introduction: Scripting Processing With MIDI
Processing is perhaps best known as a generator of sound and graphics, but your sketches cannot only create MIDI messages but listen for them as well.
The MIDI messages can come from not just some standard MIDI keyboard, but from other applications.
Even better: Your sketch is not limited to listening to only one MIDI source.
This means you can use a music program such as Renoise or Ableton Live to control a Processing sketch both in time to music and on-the-fly.
This article is ostensibly about writing code to drive a Processing sketch from a MIDI stream, but along the way it touches on creating a configuration class for Processing, ways to structure code for the draw loop, dynamically calling methods given some text, and organizing code when you are still largely experimenting.
As happens when writing about code, the code evolved during the writing, so in some ways it's something like a travelogue, with some minor detours and false turns on the way to the final destination. However, all this should help in understanding the bigger picture.
The complete source code can be found on Neurogami's GitHub. Parts of it will look somewhat different from what is shown here because it kept evolving as this was written. That's the nature of creative coding.
That repo includes the Processing code covered here, the graphics used by the sketch, and a version of a track by Neurogami, "A Temporary Lattice."
Here's a video of what it looks like when all is assembled:
A Temporary Lattice (beta v1)
Step 1: Getting Started
I will assume you already know something about Processing and have it installed. I also assume you have some means of sending MIDI messages. More than one would be ideal, but is not required to play along. If you have Renoise (there's a free demo version you can grab) you can use the demo track used here.
A version of this code was created by Neurogami to drive a music video for by song by James Britt, "TR3".
The idea was to take images of circa 1979 Lower Manhattan and position them in time to the music. The images weren't still; they were run through some glitching code to generate a series of different distortions and the images were combined into videos.
In addition to the glitched images there were animated drawings created using a different set of distortions. These specifics are not essential to the use of MIDI, but the effect is good so it's used it here.
Picking a MIDI libraryProcessing, all on its own, does not know anything about MIDI. Under the hood Processing is Java so any Java MIDI library should work well with Processing. There are, however, some Java MIDI libraries that have been packaged for use with Processing, which can make some things easier.
There are two MIDI libraries for Processing that seem to come up quite often. One is proMIDI, the other is the MidiBus. I tried both and went with MidiBus. I wish I could give you some useful details as to why, but I honestly do not remember. The code described here could plausibly by ported to work with other MIDI libraries so long as they support two features: The ability to connect and listen to events from multiple MIDI devices, and callbacks that are invoked on events from any of the connected devices.
For this article go install the MidiBus library if you do not already have it.
Step 2: A Simple Sketch
This is a simple sketch to show basic behavior and to check that things work.
// SimpleMidi.pde
import themidibus.*; //Import the library
import javax.sound.midi.MidiMessage;
MidiBus myBus;
int currentColor = 0;
int midiDevice = 3;
void setup() {
size(480, 320);
MidiBus.list();
myBus = new MidiBus(this, midiDevice, 1);
void draw() {
background(currentColor);
void midiMessage(MidiMessage message, long timestamp, String bus_name) {
int note = (int)(message.getMessage()[1] & 0xFF) ;
int vel = (int)(message.getMessage()[2] & 0xFF);
println("Bus " + bus_name + ": Note "+ note + ", vel " + vel);
if (vel > 0 ) {
currentColor = vel*2;
First a quick run-through: When you run this you should see (either in the Processing IDE message window, or in a terminal window, depending on how you run it) a list of available MIDI inputs and outputs. In my case I've attached a QuNexus MIDI keyboard that happens to come up as input number 3, so that's the value I assigned to midiDevice. (I don't care what output device is selected to I just set it to 1.)
The sketch pops up a window that will change shades of gray based on the velocity of whatever MIDI not you send it.
If you are not using device that sends variable velocity then the visuals will not be terribly interesting. You will still see the assorted println details though.
What's happening in this sketchFirst up you need to import the MidiBus library (themidibus) but also a Java library (javax.sound.midi.MidiMessage) so that your code can refer to MidiMessage objects (as happens in this sketch).
Depending on what you want to do with the methods available via MidiBus you may need to import other Java MIDI files, but for this example just that one will do.
In setup the sketch initializes the MidiBus instance myBus. When you create a new instance of a MidiBus class you need to pass in a reference to the current sketch (AKA this), the index of the device to listen to, and the index of the device to send to.
If you want to see what devices are available you can call MidiBus.list() which prints (to STDOUT) the lists of available MIDI input and output devices. The number that appears to the left of an item is the index number you use when creating your MidiBus instance.
If you wanted to be really clever you might wrap this up into some sort of GUI (perhaps using ControlP5) so that the devices can be set or changed after the sketch is started. In practice, though, the devices are unlikely to change from one run to the next and hard-coding them is probably good enough for most cases. Another option is to have your sketch load these values from a configuration file so that if and when you need to change them it is a bit easier to do.
Once a MidiBus instance has been created, and a suitable sketch window, it's time to wait for some MIDI input.
A global variable, currentColor, is in place to hold the gray-scale value for the sketch background. All draw does is use this value to color the window. Yet if you are sending MIDI notes to the sketch the window changes. Where is the change occurring?
MidiBus provides a few callback methods. These are methods that are automatically invoked under various conditions. This sketch uses midiMessage, which is automatically called whenever a MIDI message arrives.
There are two versions of midiMessage; the other one has just one argument for the MIDI message. This sketch uses a version that includes the time-stamp and MIDI bus name just to show some of the MIDI details you can get.
You decide what happens in this method. For this sketch the code grabs some info about the MIDI message and prints it, and then looks at the note velocity. If the velocity is greater than zero then that value is doubled and assigned to currentColor.
Why skip values of zero? The MIDI specification defines messages for both "note on" and "note off". But some devices don't bother with "note off", instead sending a "note on" message with a velocity of zero.
When I was first writing this sketch I simply grabbed the velocity and used it, and saw that the screen went black a soon as I took my fingers off the QuNexus keys. Watching the println output I saw what was happening: zero velocity for "note off".
How you handle this is up to you; just be aware that it can happen.
So this is quite the simple sketch but demonstrates a key idea: The sketch waits for external signals, responds to those signals by updating some variables, and each pass of draw uses the current state of those variables to do something.
Step 3: Configuration, and Getting Clever
If you write enough Processing sketches that depend on some initial settings that you need to adjust for different executions you are likely to do as I did and work out some way to load such settings from a configuration file. I suspect this is the kind of coding that falls into the "How hard can it be?" category since I don't think I even bothered to look for an existing solution. Instead I did something really simple and adjusted it over time.
My first Config class loaded a text file from the data/ folder and parsed name:value strings into a HashMap. It worked pretty well for most things. Great for simple single-item entries, but not so good if you wanted to define a list of values.
I got to wondering if I could use YAML or JSON so that a text file could represent more complex structures. Turns out that Processing gives you built-in JSON handling. Perfect.
For the MIDI sketch the configuration was updated to use JSON. Loading a JSON file and getting at the values is mostly easy but not entirely transparent. You can get at different types of data using getInt, getFloat, getString, etc., but if you want to grab a list of items you need getJSONArray and then need to pull out each item as the correct type.
For this Config I decided that in most cases any list of items will be of the same type. So I added getStrings ,getFloats, and getInts.
Now instead of putting the devices indices into my sketch I could use a config file. JSON is not as simple as name:value but it's not too far off from that. A bit overkill for short files, very handy for more complex structured data.
I won't get into the details on that code here. You can read more about it here.
That first demo sketch showed one way to create a MidiBus object. There's another way, and it's not only more friendly but lends itself to better configuration. MidiBus lets you specify what devices to use by name. The name has to match on what is displayed in the list of available devices, so you may need to first run MidiBus.list to see what's there.
Once you know the names of things the configuration file can use readable text instead of cryptic numbers.
You can also pass in a name for the bus so that later, when midiMessage is invoked, your code can (if you like) behave differently based on the source of the message.
Now the demo sketch (minus the code for Configgy.pde) looks like this:
import java.lang.reflect.Method;
Configgy config;
ArrayList devices = new ArrayList();
void setup() {
size(480, 320);
config = new Configgy("config.jsi");
String[] deviceNames = config.getStrings("devices");
println("Unavailable Devices");
println( join(MidiBus.unavailableDevices(), "\n"));
println("-----------------------------------------------------");
String[] available_inputs = MidiBus.availableInputs();
for (int i = 0;i < available_inputs.length;i++) {
for(int x=0; x < deviceNames.length; x++) {
println("Check for device " + deviceNames[x] + " against " + available_inputs[i] );
if (available_inputs[i].indexOf(deviceNames[x]) > -1 ) {
println("* * * * Add device " + deviceNames[x] + " * * * * ");
devices.add( new MidiBus(this, deviceNames[x], 1, deviceNames[x]) );
if (devices.size() < 1 ) {
println("Failed to assign any of the desired devices.\nExiting.");
exit();
void draw() {
if (vel > 0 ) { currentColor = vel*2; }
The config.jsi file (stored in the data/ folder) is this:
devices:["QuNexus", "01. Internal MIDI"]
You'll have to adjust this to whatever devices you have available to use.
When you run the sketch, your config file will be loaded and the code will try to populate an ArrayList with MidiBus instances based on the device names you provided.
Note that in this example the use of an ArrayList means the code is not bothering with specific instance variables for every MidiBus instance; this code doesn't ever reference those instances.
The midiMessage event handler gets called no matter which of those devices is sending the message. The handler is passed the name of bus so you can, if you like, have the code take different action depending on the source of the MIDI message.
If you're wondering why bother adding the bus instances to a list if they're never going to be used, the reason is that without some kind of persistent assignment those instances will disappear once setup has completed. Once they are gone, the MIDI message event handler will no longer get called.
If you did want the code to reference any of these instances then you might consider using a HashMap to hold them so that you could retrieve specific devices by name.
Step 4: Where We Are So Far
Here's a recap before we move on:
- You can use MidiBus.list() to see what devices are available
- To create a MidiBus instance you can use the index of a device, but you can also use the device name as shown by MidiBus.list()
- Configgy lets you create a configuration object using JSON so you store a list of device names.
- The event handler middiMessage is called for all messages that come from any of the MidiBus objects you have in your sketch
- middiMessage can give you the name of MIDI device if you need it (plus, of course, the MIDI message details)
No mention has been made of sending MIDI messages from a sketch. You can use MidiBus for this as well, but that's not going to be covered here. (However, sending basic notes comes down to getting a MidiBus instance for an output device, and then using that instance to call sendNoteOn(channel, pitch, velocity). But there are more things you can do, particularly with sending custom MIDI messages.)
Step 5: Custom Message Handlers
Using midiMessage is OK for simple cases, such as having the sketch do something no matter what note is sent, or perhaps selecting behavior based on two or three notes, but if find your code filling up with lengthy if/then or switch/case statements you should be wary. These kinds of structures can become hard to maintain.
What would be cleaner than a growing set of conditionals would be a way to invoke a method based on the note value. Here's one way to do it:
invokeNoteHandler(note, vel);
void invokeNoteHandler(int note, int velocity) {
try {
Class[] cls = new Class[1];
cls[0] = int.class;
Method handler = this.getClass().getMethod( "onNote" + note, cls );
handler.invoke(this, velocity);
} catch (Exception e) {
e.printStackTrace();
When a MIDI message arrives, midiMessage pulls out the note value and velocity. It passes those values on to invokeNoteHandler. That's where the fun happens.
Java reflection allows code to find methods by name (using getMethod) and call them. We want to pass an int value to some method of the form onNote<SomeNoteValue>; to find a method you need to both the name and an array of classes describing what arguments that method takes.
Once a reference to such a method is found it is invoked using (surprise!) invoke.
This all happens inside a try/catch block. If something goes wrong (for example, the code tries to find and call a method that doesn't exist) the exception is more or less ignored. The idea here is that we will have methods for some set of notes, and we don't care about notes for which there is no corresponding handler method.
The last part of this is to define one or more methods to do something for specific notes. For example:
void onNote48(int vel) {
void onNote50(int vel) {
Not terribly imaginative, but what this does is limit screen-color changes to just two notes.
Here's maybe a better example:
First, change the type of currentColor:
color currentColor = new color(0,0,0);
Now have the note handlers set different colors:
if (vel > 0 ) { currentColor = color(255, vel*2, vel*2); }
if (vel > 0 ) { currentColor = color(vel*2, 255, vel*2 ); }
void onNote52(int vel) {
if (vel > 0 ) { currentColor = color(vel*2, vel*2, 255); }
The key point is that the behavior for any given note is encapsulated in its own method instead of being crammed into one growing catch-all method.
We can make things cleaner yet by putting all the note-handling methods into a separate file (e.g. noteHandlers.pde) so you know exactly where to look to add or change anything.
Your own message handlers can be anything you want, and you may want to pass in other parameters, perhaps pass in the original MIDI message itself. However you set it up you need to set up your version of invokeNoteHandler so that it locates methods with the correct parameter signature.
For example, if you want to use handler methods that take the note velocity and the bus name, you need to change the Class array used with getMethod to indicate the types of these two parameter:
void invokeNoteHandler(int note, int velocity, String busName) {
try {
// An array of size 2 since we are looking for a method that
// takes two arguments
Class[] cls = new Class[2];
cls[0] = int.class;
cls[1] = String.class;
// Now call the located method with the two arguments
handler.invoke(this, velocity, busName);
Step 6: A Multimedia Extravaganza
What we have so far is a way to listen to any number of available MIDI input devices and dispatch to specific handler methods based on note value.
What initially drove this code was wanting to take a song created using a DAW (in this case Renoise) and generate visuals that changed in time with the music.
Renoise (and no doubt other audio software) can not only record MIDI notes but can itself be a MIDI message source. A song track can be devoted to sending MIDI notes without triggering any specific sound. This can be used to trigger events on a Processing sketch.
Using a Renoise track to only send MIDIIf you do not already have Renoise you can download a demo version for free. The explanation here is for the current official release, version 2.8.2
When you open up a Renoise song, or create a new one, you can set up a track that plays MIDI notes while not triggering any sound in the song itself. (The Renoise song included with the source code already has these tracks set up.)
It is instruments in Renoise that send external MIDI, not tracks. A track can make use of any of the instruments in the song, but it is common for tracks to be mapped to specific instruments. This can make it easier to organize what's making what sound.
Tracks are broken up into patterns, with patterns containing some number of lines; these lines hold the commands to play notes, trigger samples, and control effects. Commands to play notes map to instruments. Usually these instruments are there to make sounds, but there's no requirement for that. That allows you to create a soundless MIDI-trigger track.
Using Renoise MIDI to trigger external applications
To do this, select or add a new, empty track. Give it a sensible name; I'm prone to calling such tracks "MIDI TRIGGER", all caps, so that it stands out as something special. I also like to set the track color to either white or black, while all the actual music tracks are assorted shades of red, blue, green, and so on.
Now select an empty Instrument slot in the upper right. Since you do not want any sound generated you need to make sure no actual instrument is assign to that slot.
With that unassigned-instrument slot selected go down to the bottom and select the "Instrument Settings" tab. Click on "Ext. MIDI" and select a device. For example, "01. Internal MIDI". (Your choices will depend on what's available on your machine.)
While still on that tab you can, if you like, name this "instrument"; it says "Untitled Instrument" by default but you can click on that and edit it. Maybe call it "MIDI TRIGGER". Now you can see this name up in the instrument panel up top.
With that no-sound instrument selected go to your MIDI TRIGGER track and enter notes. When you play the song these notes will be sent out on the external MIDI device you assigned to the no-sound instrument.
By the way, you can assign an external MIDI device to any instrument you like and have tracks that both make sounds for the song while also sending those notes to an external device. For my purposes I like keeping the MIDI triggering instrument separate because I do not intend it to mirror any specific instrument and this way I can change the triggering notes without altering the sound of the song.
The trigger notes can be any value you like (since they are not being heard). It's useful, though, to work out some kind of naming scheme to help identify what different notes are meant to do. For example, one octave (starting at C4) could be was used to alter video images placed in assorted grid locations on the right side of the screen. Notes in another octave (at C5) might alter the left side of the screen, and so on. (We'll see later on that there are other ways to organize you notes and handlers, such as using channel and MIDI device name.)
Depending on the complexity of your sketch you may want a chart of some kind to map note names to note values. Renoise, for example, displays notes as letters and octave; you see "C4" instead of "48".
With the current state of the demo sketch you need to limit the notes to the values C4, D4, and E4 (since those are the only handlers defined so far). As written, these handlers will show the color white when the note velocity is 100% (i.e. 127). If you enter the notes using a velocity-sensitive keyboard (such as the handy QuNexus) then you can get a variety of velocity values below the maximum. If you are entering them by hand (using perhaps you computer's "Z", "X", and "C" keys) you can go back and edit the velocity of each note (which are, by default, the maximum).
Now if you configure the demo sketch to listen to the same device as the MIDI trigger instrument uses the sketch should react as each trigger note is played.
Step 7: We Can Do Better
Let's now take all this and see if we can make it a bit more exciting.
First, an important caveat: The Neurogami aesthetic may not be yours. It's a kind of glitchy minimalism. I do hope you like it, but that's not really the goal here.
The approach taken was to first create a number of animated GIFs made using ImageMagick and some custom Ruby software to glitch images. The Processing code then places, scales, etc., this or that GIF file based on what MIDI note and channel comes in.
It's probably more common to see Process sketches where all of the visual effects are done by Processing (or some additional Processing library) right in the sketch. There approach here is, in way, cheating: it's just showing pictures of graphic effects. So what: It's the end result that matters.
However, using pre-made animations does make things easier. Getting the same visual effects real-time in Processing would be nigh impossible. Couple that with also responding to MIDI messages in real-time makes it more likely for things to go wrong.
There is something about this sketch that is common to most Processing sketches. If you look at most any example that renders something visually striking the sketch generally works like this: On each pass of draw, run some code to update a set of variables, then use the current state of those variables to determine what to render.
This sketch is the same. It uses a very slick library called gifAnimation to play animated GIFs. You can use them as you would any regular image file, that is, pass a reference to an animated GIF to image to control the placement and scaling.
The thing is, if you are looking to render numerous images in varying places, some persisting some not, you need some way to keep track of them. If you knew the exact number of images you might be able to use a fixed set of variables to hold all the details, but past some small number that gets cumbersome.
I had in mind to render the GIFs placed into grids of different sizes. I decided to split the screen in half, down the middle. Image placement would be done by specifying left or right, what size grid (by giving the number of rows and columns), and where in that grid to place the image.
Tracking a set of related data calls for some way to group them. Sometimes an array works, but in this case there needs to be two sets of grouped data. Making your classes in Processing is easy and affords a way to keep related data together. I defined a class called RenderArgs (you'll see why in a moment)
class RenderArgs {
public color tint;
public Gif gif;
public int numCols = 0;
public int numRows = 0;
public int slotIndex;
RenderArgs(color t, Gif g, int nC, int nR, int idx ) {
tint = t;
gif = g;
numCols = nC;
numRows = nR;
slotIndex = idx;
It's just a way to group a tint color, a reference to an animated GIF, the number of columns and rows in a grid, and where in that grid to place the GIF.
These (except for the tint) are all arguments to a method placeGifAt.
void placeGifAt(Gif g, int leftOrRight, int numCols, int numRows, int slotIndex ) {
int w = width/(numCols*2);
int h = height/numRows;
int count = 0;
int colOffset = 0;
if (leftOrRight == RIGHT ) {
colOffset = width/2;
for(int y=0; y<numRows; y++) {
for(int x=0; x<numCols; x++) {
if (count == slotIndex) {
image(g, x*w+colOffset , y*h, w, h);
count++;
(The file with this code also defines RIGHT as 1 to make this more readable.)
Plausibly, this method could be part of the same class that holds all of the argument values; the code evolved from first creating a method to define how to place an image in a grid-slot.
placeGifAt gets called in draw, along with a call to tint. All this could be wrapped up in an instance method (render, perhaps) in renderArgs (which would then need a better name) so that data and behavior are kept together (sort of the whole point of classes). I just haven't done this. I'm still trying things out and I'm OK if code hasn't settled into some final form.
There are assorted helper methods that manage a list of animated GIF instances and a list of tints, and some ArrayList instances (renderL and renderR) to hold on to RenderArgs instances.
draw does very little. It sets a black background then iterates over the RenderArgs lists, and for each item calls tint then image. In other words, it looks at a set of variables and uses them to decide what to render.
Here's draw
void draw() {
background(0);
RenderArgs ra;
for( int i =0; i < renderL.size(); i++ ) {
ra = renderL.get(i);
tint(ra.tint);
placeGifAt( ra.gif, LEFT, ra.numCols, ra.numRows, ra.slotIndex );
for( int i =0; i < renderR.size(); i++ ) {
ra = renderR.get(i);
tint(ra.tint);
placeGifAt(ra.gif, RIGHT, ra.numCols, ra.numRows, ra.slotIndex );
Step 8: What's That Channel?
Since draw doesn't do much the real action must be happening elsewhere. Indeed, it's the note-handling methods that drive what is seen. When a MIDI message comes in it gets dispatched to a matching note handler if one exists. I decided I wanted to be able to generate some patterns, such as filling up a 4x4 grid with images note-by-note. I wrote a note handler that did this for the left side of the sketch window, and thought it would be nice to do the same on the right side, but reversed.
At first I did this using two different note handlers, thinking I would use one octave for things to happen on the left side, and another octave for the right. This felt awkward. Why not get channels involved?
MidiBus provides some additional event handlers, including noteOn, which, if you define it, gets called when any device receives a note-on message. This method will give you the channel, the note value, and the velocity. However, it does not give you the name of the MIDI bus that received it.
At this point in development I did not have a clear plan for using the bus name but some ideas were forming and I did not want to drop the option of using it. But I wanted the channel, too.
midiMessage is called with some specific data handed right to you (such as the bus name) but the message itself is somewhat cryptic. You may have noticed there's some interesting math going on to get the note and velocity values.
A MIDI message is pretty compact. It is sent as a series of bytes. I'm going to skip the technical details but to get the useful value of these bytes in Java you need to grab a subsection of them and then apply a "mask". This mask forces some part of the value to assume a certain value giving us a useful result.
The code was doing this to get the note and velocity values. They same approach can be used to get the channel as well. midiMessage then becomes this:
int channel = (int)(message.getMessage()[0] & 0x0F) + 1;
invokeNoteHandler(note, vel, channel, bus_name);
invokeNoteHandler now needs to do a method look-up with three arguments:
void invokeNoteHandler(int note, int velocity, int channel, String bus_name) {
try {
Class[] cls = new Class[3];
cls[0] = int.class;
cls[1] = int.class;
cls[2] = String.class;
handler.invoke(this, velocity, channel, bus_name);
println("* * * * * * Error handling note " + note + " * * * * * * ");
e.printStackTrace(); }
With both channel and bus name available each note handler can behavior differently depending on the source of the note. In some cases this makes it easier to organize the notes at the point of origin. For example, I created a method that would keep adding an image to 4x4 grid, tracking a grid index. If the index went out of bounds (that is, below 0 or above 15, depending on which direction was used to fill the grid) the grid would be cleared.
I assigned this the C4 (i.e. note 48). Before bringing channels into the code I had C64 trigger this behavior on the left side of the sketch and C5 used to trigger it on the right (where it would run in reverse, starting from grid location 15). But I wasn't happy with this use of octaves. Deciding to add channels I created another MIDI-trigger instrument in Renoise and set it to output on channel 2. This way I could set up each note to map to some specific behavior, with the channel determining on what side of the screen it would appear.
These kinds of organizing decisions are quite subjective. This works for me (so far; perhaps after more use I'll work out some other scheme). The point is that there is no one true way to do this; find an approach that works for you.
Here's how onNote48 ended up after that change:
void onNote48(int vel, int channel, String bus_name) {
if (vel > 0) {
switch(channel) {
case 1:
addToGridL4x4();
break;
case 2:
addToGridR4x4();
break;
addToGridL4x4() is this:
void addToGridL4x4() {
if (gridL4x4Pointer < 0) {
renderL.clear();
gridL4x4Pointer = 15;
renderL.add(new RenderArgs( nextTint(), gifs[nextGifIndex()], 4, 4, gridL4x4Pointer) );
gridL4x4Pointer--;
The general scheme is the use of a variable to track an index into a grid, updating the index, and making sure it always has a valid value.
At some point the global variables need to go away and all this wrapped up into a class, but the loose mutability lends itself to interesting behavior.
Step 9: Yet Another Bus ...
You can look at the final source code to see what I came up with for note handlers, run it with the example Renoise file, or watch the video to just see it in action. There's a very good chance that the code will not be exactly what I've shown here. As I've been describing the sketch I've been reconsidering how things should work. This is the nature of exploratory coding.
While trying out this and that I realized that it can be hard to pre-plan every change and switch and jump you might want to see in the sketch. As I would alter code or edit the MIDI tracks in Renoise and watch the results I kept thinking, hey, a sudden tint change would be good, or this would be the right beat to throw up dual full-sized images for half a bar. In other words, there were a few select effects I wanted but only at key moments.
Editing this into the Renoise trigger tracks would be tricky. So much nicer to activate some things in real-time using another controller as the song plays.
I had started off experimenting with my QuNexus keyboard. This device allows you shift the octave so I could have worked with a range of notes not already assigned. But I wanted to use a controller that might be more intuitive, something other than a standard keyboard.
I picked up a Novation Launchpad sometime last year. It's a grid of touch-pad switches. There's no velocity control, just on/off, great for triggering samples and loops and such. It sends MIDI notes within a preset range. Now, I sure there's a way to change what notes are assigned to each button, but since the bus name is passed on to the MIDI note handlers in the sketch I can safely reuse the existing notes.
Another approach might be to set the Launchpad to use a specific channel. You can decide for yourself whether selecting behavior on yet another channel or branching based on bus name better fits you mental model of what's happening.
There are various places the code can switch behavior based on bus name. One, of course, is inside any of the note-handling methods. Another would be in invokeNoteHandler. Although I've been passing the bus name on to the note handlers my ideas for how to use the Launchpad didn't feel like a good fit for the existing note handling code. For example, if I send C48 from the Launchpad I'm might not be looking to do another variation on the 4x4 grid-fill pattern, but something quite different. Adding a test in onNote48 for this particular device felt clunky. Suppose I defined a different set of note handlers, specific to this device?
This would save me the trouble of having to add this device-name check to every single onNoteNN method on the off-chance there's a note value overlap. The downside is having a device name hard-coded in my sketch.
... and yet another configuration option
While I wanted to dispatch certain MIDI messages to select handlers based on bus name I did not want to hard-code the bus name. At home I have a choice of controllers, but as I write this sentence I happen to be at HeatSync Labs. I did not bring the Launchpad; the QuNexus fit much better into my laptop bag.
Rather than rely on the name of a specific controller in the code I added another configuration option to allow mapping device names to some other text.
The config.jsi entry looks like this:
device_mappings: {"Launchpad": "grid", "QuNexus": "grid" }
In sketch the code that sets up devices now also looks to see if there is a device mapping for a found device, and if so then it uses that mapping name as the bus name rather than then given device name.
This required yet another change to Configgy.pde. What's new is that you can store a name:{} setting and get back a HashMap of name/value string pairs.
So the sketch grabs these device name mappings ...
HashMap mappings = config.getHashMap("device_mappings");
... and then later ...
if (mappings.containsKey( deviceNames[x] ) ) {
println("+ + + + Add device using mapping " + mappings.get( deviceNames[x]) );
devices.add( new MidiBus(this, available_inputs[i], 1, (String) mappings.get( deviceNames[x]) ) );
} else {
devices.add( new MidiBus(this, available_inputs[i], 1, deviceNames[x]) );
Now the MIDI message dispatching code can look for messages from a bus named grid; the actual device could be any number of devices depending on what you've attached and how you've mapped names.
Now dispatching on MIDI messages can call specialized handlers:
try {
cls[0] = int.class;
cls[1] = int.class;
if (bus_name.equals("grid") ) {
Method handler = this.getClass().getMethod( "onGridNote" + note, cls );
} else {
println("* * * * * * Error handling note " + note + ", velocity " +
velocity + ", channel " + channel + ", bus_name " + bus_name + " * * * * * * ");
Step 10: Gridly Goodness
This setup allows multiple devices to lay the role of grid. What's left is to add some final flourishes.
The bulk of the graphics happens on a split screen. One more rendering structure that covered the entire screen would be nice. To this end, an new RenderArgs ArrayList instance is created.
A few more tweaks get introduced as well. The option to set a scaling factor when rendering a GIF. This allows two interesting features: You can center a large GIF that would not otherwise fit int a uniform grid (since you can place it near the upper left and then scale it), and you can grow/shrink GIFs as they are show.
The default MIDI mapping for the legacy Launchpad looks like this remarkably sophisticated chart:
(104) (105) (106) (107) (108) (109) (110) (111) [ 0] [ 1] [ 2] [ 3] [ 4] [ 5] [ 6] [ 7] ( 8) [ 16] [ 17] [ 18] [ 19] [ 20] [ 21] [ 22] [ 23] ( 24) [ 32] [ 33] [ 34] [ 35] [ 36] [ 37] [ 38] [ 39] ( 40) [ 48] [ 49] [ 50] [ 51] [ 52] [ 53] [ 54] [ 55] ( 56) [ 64] [ 65] [ 66] [ 67] [ 68] [ 69] [ 70] [ 71] ( 72) [ 80] [ 81] [ 82] [ 83] [ 84] [ 85] [ 86] [ 87] ( 88) [ 96] [97] [98] [ 99] [100] [101] [102] [103] (104) [112] [113] [114] [115] [116] [117] [118] [119] (120)
There are circular buttons across the top and along the right side; the main layout is an 8x8 grid. The numbers in that chart are the MIDI note values each button sends by default.
Some things to note: There are gaps in the note ranges, and note 104 is repeated twice, first at top as the first button and again on a button on the lower right.
I wanted to relate pad position to some aspect of an effect to make it more intuitive. As you might have guessed by now it's in constant flux, but here's some examples.
The Renoise track was set up to send some fairly structured sketch triggers. For example, generating a grid-filling sequence.
For the onGridNoteNN messages I wanted to be able to place and scale GIFs across the full sketch window.
As before, there's a list to hold data for placing GIFs on the screen and methods add items and clear the list.
The focus is on section of the Launchpad: the first five columns (from the left) and the top three rows.
Moving across the pads in a row places a GIF in a relative screen location (far left, kinda left, center, etc.). Moving from the first row to the third sets different GIF scaling; lower is larger.
Hitting the pad for note 32 places a GIF that fills the entire left side; note 36 fills the right side.
Controlling the sketch using the Launchpad
All of this works off a grid 8 rows by 16 columns. The difference is in the scaling factor used. Adding a GIF to the remderC RenderArgs list involves calling this method:
void placeGif8x16(int index, float scaling ){
gridCRows = 8;
gridCCols = 16;
gridCPointer = index;
centerScaling = scaling;
addToGridC();
where addToGridC is much like addToGridL4x4.
And, much like earlier code, there's use of assorted global variables controlling grid indexing and scaling.
Warning: May cause side-effects
A great deal of Processing code I see makes copious use of global variables. That is, variables that can be accessed and possibly altered for any place in the sketch.
Generally such things make me cringe. But why? And if it's so cringe-inducing why am I doing it here?
There's is some good coverage of the perils of global variables here and here.
In a nutshell, global variables are just that: globally variable. When a method, such as placeGifAt uses a global variable (e.g. centerScaling) there's no assurance what value that variable may have.
The value may have been set by one method, but then later changed by another, before placeGifAt gets to use it. This high degree of mutability makes it very hard to understand what is going to happen when placeGifAt is called. Indeed, it's quite possible that centerScaling may end up with a completely unusable value. When something does not behave correctly, where do you look to understand why? If a value used in a method could be changed from anyplace in your code, how do you control it?
Many Processing sketches are quite small. They fit into one file, and are for the most part easy to look through. If a sketch is not terribly complicated then tracking down odd behavior is maybe not a big problem.
Starting off a small program using global variables is not a major sin, and can make it easier to jump in, try stuff, and judge the results. This kind of exploration should be encouraged.
As code grows, though, the downside of side-effects resulting from global variables changing in ways that conflict with intended behavior can grow. It can make sense to start encapsulating these variables, and the ways they can be accessed, into classes.
In the case of exploratory code, and perhaps creative coding in general, these side-effects can be an accidental blessing.
As I wrote the handles to react to Launchpad messages I added methods that populated a list of GIF-placement information. The actual placing of these GIFs uses the common global value of centerScaling.
Without realizing the consequences I had my methods change the value of centerScaling. The unintended result was that all existing GIFs in renderC were changing size whenever a method altered the value of centerScaling.
Not what I was planning, but I like the effect. If and when I corral the code into a less haphazard structure this kind of behavior may be something I'll want to keep.
Step 11: Wrapping Up
I'm happy with what this so far. I'm happy, too, to keep playing around and changing things.
Over time I can see parts of this sketch being extracted into something more reusable.
If you're wondering how the final results are to be captured and turned into video, I've been experimenting with some screen-capture software. If you've been playing along at home you may have noticed, depending on how beefy is your setup, that the rendering of the GIFs when viewed on their own (say, in a browser) are different than when they appear in the sketch. As part of a collection of a dozen or so images that come and go the GIFs tend to show more jitter and lags. Perfect!
Likewise, when I've done some test recordings using a screen-capture tool I end up with similar sorts of glitches and artifacts. There's little point in trying to prevent this. It may be possible but I'd rather embrace the quirks of a given tool or medium. That's a big part of the fun.
I do want things to be synchronized, and if need be I can adjust that in some video tool, but for the most part what I've been getting is a stable coordinated structure at the larger level with odd coincidental "errors" happening within that.
Step 12: Coda
After endless playing I decided that it would be nice if I could record my QuNexus/Launchpad improvisations in case I end up with something I really like. I set up a new track in the Renoise piece, and added the QuNexus as a MIDI input. But once Renoise was capturing that device it was no longer available to the sketch. Quandary.
This got me thinking of routing grid messages based on channel number. This way Renoise can capture notes from whatever is supposed to be the grid device and output on some specific channel (3, perhaps). Now the behavior should be the same as if the grid device were directly talking to the sketch while all notes were recorded by Renoise.
