Introduction: Sea Anemone Lamp
we are be going to build a sea anemone lamp
you can use it on table or in sleeping room
Step 1: Materials
hi every body
we need some materials:
1- a foam spray
2-a small LED panel + colored film for change the color of LED (if needed)
3- some glue sticks
4- a cutter and a pencil for cutting and make holes in foam
Step 2: Making
drain foam spray on a flat, clean and polished surface (it is preferred that don't use the spray cap and pipe) so after a while we will have a foam rock
dig a concave hole (dome shape) under this foam rock
make some holes in foam from top to bottom
now put the hot melt glue sticks in the holes and put the assembly on the colored LED panel
Step 3: Safety Aspects
LED panel may heat the "Sea anemone lamp" so be careful about overheat and fire
