Introduction: Seashell Headphones
These are the seashell headphones, which you can put on your head. Put them on, and listen to the sounds of the sea come into both of your ears.
You will need the following supplies:
2 sheets of origami paper 1 sheet of colored cardboard(preferably size A4) 1 glue stick 1 roll of tape At least 6 flat, circular pieces 2 seashells
Step 1: Step 1: Cut Ribbons.
First thing you need to do is to cut the colored cardboard into ribbons, at least 5 cm thick. There should be at least 3 such ribbons.
Step 2: Step 2: Glue Ribbons.
Gather your ribbons(must be at least 3), and glue them one on top of the other. That way, you will end up with a single, thicker ribbon. This will be the headband for your headphones.
Step 3: Step 3: Papering Up the Seashells
Gather up your origami paper sheets and your seashells, because in this step you will need them. Cover up a seashell in glue, and then wrap it around in a single sheet of paper as much as possible(while leaving space for the sound to come out of the shell's orifice). Do the same with the second shell.
Note: If you happen to run out of paper, feel free to use any additional paper to cover up any missed parts.
Step 4: Step 4: Sticking the Shells to the Headband.
Now, this is the part, where each shell is attached to each end of the headband. To an end of the headband tie together a seashell with tape. Make sure to leave open the part between the shell's sections. Do the same with the second seashell.
Step 5: Step 5: Sticking the Flat Pieces.
Now gather up the flat pieces mentioned before, and stick them onto the top of the headband. One after another, so that the headband would be covered in the pieces. Make sure there is equal distance between each piece.
