Secret Arduino Voltmeter
Introduction: Secret Arduino Voltmeter
About: ProvideYourOwn.com is a website devoted to people who want to make their own things and provide for their own needs. We provide information, encouragement and resources to empower people to become free from th…
A little known feature of many AVR chips is the ability to measure the internal analog voltage reference. This trick can be used in all sorts of ways such as:
  • Monitoring battery voltage to your Arduino
  • Checking to see if A/C power is running
  • Improve accuracy of analogRead() in many situations
The way to perform these feats is use the internal reference to actually measure Vcc. In the code following, we will actually measure the internal voltage reference, and then use this value to calculate our actually Vcc. Here is the code:
long readVcc() {
  // Read 1.1V reference against AVcc
  // set the reference to Vcc and the measurement to the internal 1.1V reference
  #if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
    ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
  #elif defined (__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
     ADMUX = _BV(MUX5) | _BV(MUX0) ;
  #else
    ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
  #endif
  delay(2); // Wait for Vref to settle
  ADCSRA |= _BV(ADSC); // Start conversion
  while (bit_is_set(ADCSRA,ADSC)); // measuring
  uint8_t low  = ADCL; // must read ADCL first - it then locks ADCH
  uint8_t high = ADCH; // unlocks both
  long result = (high<<8) | low;
  result = 1125300L / result; // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000
  return result; // Vcc in millivolts
There are some limitations in accuracy due to tolerances on the internal voltage reference. You can however, calibrate the scale factor for greater accuracy. This code runs on all Arduino variants as well as the ATtinyx4 series chips.
For a more in-depth article, which includes calculation details, applications and calibration how-to, see Secret Arduino Voltmeter – Measure Battery Voltage.
Electronics Tips and Tricks
Be the First to Share
    • Big and Small Contest
    • Make It Bridge
      Make It Bridge
    • Game Design: Student Design Challenge
    5 Comments
    gert3d
    gert3d
    4 years ago on Introduction
    Thanks, I used it for a Pro Mini and indeed got correct results when powering from USB or battery. However it turns out that the result stays constant unless the Pro Mini is reset. Should there be some initialisation to reset the previously measured value?
    majrooo
    majrooo
    10 years ago on Introduction
    Thanks, great stuff. Can you modify the code for atmega1284P?
    latestrevision
    latestrevision
    Reply 6 years ago
    I'm sure you already sorted this out on your own, but, for future readers, you can use the same calculation used for the ATmega1280 for the ATmega1284.
    james34602
    james34602
    Can it operate in higher voltage may be 70V , 110v, etc
    ooda55
    ooda55
    Yes, with the appropriate voltage divider. The chip must only receive max 5 volts on the ADC.
