Introduction: Secret Base Door Tutorial
Follow These Steps To Make A Hidden Doorway With Pistons And Water!
Step 1: The Set Up
Dig A 2x1 Hole In The Ground Like Seen Here.
Step 2: First Two Pistons
Add Pistons In The Hole Made,Make Room For The Redstone And Put Stone On Top Of The Pistons.
Step 3: Coneccting the First Redstone Circuit.
Add 2 Repeaters Facing Towards The Pistons And Connect Them To A Lever To Turn Them On Or Off.
Step 4: Second Set of Pistons.
Add Two Pistons In The Way Shown In The Picture.
These Pistons Will Close The Top Half Of The Door.
Step 5: Connecting the Second Set of Pistons.
Connect The Pistons To The Same Lever As The Other Two Pistons.
Its Recommended To Add A Repeater Close To The Lever Like In The Picture To Be Able To Get The Current To The Other Side Of The Door.
Step 6: Make It Look More Pleasing to Look at and Also to Not See the Redstone.
Step 7: The Water's Chamber.
Make A Structure On Top Of The Building Like In The Picture.
Step 8: The Hole for the Water.
Add A Small 2x1X3 Hole In The Structure.
This Is Where We'll Keep The Water.
Step 9: The Last Set of Pistons.
Add Pistons Like Seen Here.
These Will Be Used Like A Gate For The Water.
Step 10: Connecting the Inverter.
Connect The Pistons To An Inverter Wich Is The Block With The Redstone Torch.
Dont Worry If It Turns On,Later The Lever Will Turn It Off.
Step 11: Last Redstone Set Up.
Connect Redstone From The Lever TO THE BLOCK WHERE THE REDSTONE TORCH IS ON.
DO NOT CONNECT IT TO THE REDSTONE TORCH!
Step 12: Ladders.
Add Ladders On The Walls On The Other Side Of The Door To Prevent The Water From Going Into The Building.
Step 13: Switch It on and Off to See If It Works.
Turn The Lever On And Of To See If It Works.
If It Did,It Means You've Built It Correctly.
If It Didn't,This Means You Might Of Set Up The Redstone Wrong.Take A Look At The Other Steps To See If You Might Of Done Something Wrong.
If You Still Don't See Whats Wrong,Here's A DL Like To The This World:
https://mega.co.nz/#!EYc30SRT!bUjh3Kc162Avka3mkYjk...
ENJOY!!!
