Secret Box Stash
Intro: Secret Box Stash
A box with a false bottom, virtually impossible to notice.
STEP 1: Overview of Awesomeness
Ever have something you just wanna stash away? Something you'd like to hide from others? Weapons, Porn, Drugs, Sexiness? Can't find anywhere good enough?
This box stash is perfect! PERFECT.
STEP 2: Construction Materials & Supplies
Materials:
1. Sexiness, or something to hide.
2. Box, Drawer, something similar.
3. Supports.
a. Erasers
b. Pencils
c. Bits of wood, etc
4. Material for false bottom
a. Wood
b. Cardboard
c. Paper Mache
d. Whatever else you can find.
Supplies:
1. Drill
2. Glue
3. Extra sexiness, just in case you've lost yours already...
3. Supports.
a. Erasers
b. Pencils
a. Wood
b. Cardboard
c. Paper Mache
Supplies:
1. Drill
2. Glue
STEP 3: Construction of 'box' -- False Bottom
False Bottom
For the false bottom, you may create it out of wood, anything, just as long as it fits discreetly inside the box so nobody notices.
For my false bottom, I made panel of wood and stained it the same color as my box, which has worked quite nicely.
STEP 4: Construction of 'box' -- Drilling Holes
Step: Drilling holes
The hole you absolutely need, would be the one in the bottom to shove a pencil/pen/stick/rod/screwdriver/etc through in order to lift the false bottom.
Optional holes: In my box, I put 4 holes in the corners of the false bottom in order to prevent going against the air pressure.
STEP 5: Construction of 'box' -- Supports
Supports
Use anything you can find, just make sure it's thick enough to hide whatever it is you're hiding. They also need to be of equal height, and reasonable. For example, you can't open up a 4" drawer to find an inch of space.
Another optional suggestion would be to glue your supports into place, however it's not necessarily needed, depending on your setup.
STEP 6: Construction of 'box' -- Supports 2
Not really a step, just another picture example.
STEP 7: Operation
Operation
To open, take any pencil or rod-like-object and insert it into the hole upon the bottom of your box, thus lifting your false bottom which will in turn reveal your hidden sexiness. Lift up the lid, then add, remove, or replace any objects or materials of your choice.
STEP 8: Scott
The following is the reason why Connor wouldn't type anything, and Mr. Sexy Scott here had to do all the typing.
Not that I mind, I mean come on. I'm sexy. =D
P.S. In case you didn't notice ((Some don't)), the keys are in alphabetical order. =3
51 Comments
stonehenge360 15 years ago
The Mollusk 15 years ago
batman96 12 years ago
DavidRobertson 15 years ago
PointyOintment 14 years ago
DavidRobertson 14 years ago
rhaubejoi 13 years ago
JamesTB13 13 years ago
dvnfntn 13 years ago
djzadjza 14 years ago
k_mart_shoppr 15 years ago
bruno13069 14 years ago
Numb-Nuts 15 years ago
the_mad_man 14 years ago
zigzagchris 13 years ago
2muchfreetime8 13 years ago
