Introduction: Secret Underground Safe
Hello everyone in thus instructable I will show you how to make a cool underground safe for less than a dollar/euro
This is my first instructable so please tell me what you think and what i can do better in a next instructable :D
Step 1: Choosing the Right Container.
This is one of the most important things because you don't want to have a container that is too small to put your stuff in, I have chosen for a glass jar because it is just big enough for my stuff witch are just a bunch of coins.
If you have chosen for a wooden box, make sure to regulary check of your wood is still in a good condition and is not falling apart due to moisture
Step 2: You'll Guess It, Choosing the Right Place to Put Your Safe Under the Ground
This is also a very important step because it is a safe and should not be found by someone else, the best spots to hide your safe are:
1: Not in a place where a lot of people walk because there is a risk of the container breaking under the pressure.
2: In a corner of your garden under the ground/grass where plants grow that don't need to be changed every year because your safe might get found while someone is changing the plants.
If you have to put your safe in a place where a lot of people walk you shouldn't choose a glass container, a wooden box would better fit that situation.
Step 3: Making the Hole
Make your hole just big enough for your container to fit in, i left 2cm space above the container to put the grass back on
Step 4: Putting the Container in the Hole
After you've dug the hole for your container put it inside of the hole you've just dug.
Then put soil over it with grass so that it will be harder to see the just dug hole.
Step 5: Make the Place Where Your Safe Is Look Like You Haven't Buried It There
After you've buried your secret safe you need to make the place look as it was before so nobody will ever find your safe by accident.
My place wasn't that clean after all but I am sure you can do this much better!
Note:
Don't forget the secret place by yourself :p
Note:
Step 6: When Finished, Have Fun Hiding Things! :)
Please use this safe yust for fun, if you want to hide illegal stuff in it i'm not responsible for any troubles you'll get yourself into
