Introduction: Seed Sower Robot
Our project is meant to be a seed sewer. It is meant to drive straight and let out seed periodically via a twitching servo. Instead of physically having to plant seeds after the land is plowed, a robot could be used to do that process for you as it takes up a lot of time. We grew up in Kansas, which people think is just a giant hunk of farmland, so we thought this would be a great project.
- Ultrasonic Sensor: detects obstacles,allowing the robot to know when to avoidone.
- 2 Gearmotors: moves robot forward andperforms turns.
- Servo Motor: Rotates 90 degreesto open and close seed-container
- 3D printed Shell: Covers the vitalcomponents of the Arduino board.
- Funnel: Seed storage unit
- Cardboard Skids: Allow for a perfectly horizontal body
- Gift Card: Attached to the servo motor
Step 1: Design Circuit Board
- Connect the Arduino Uno to the breadboard by wiring "5V" to "+" and then wiring "GND" to the negative "-".
- For the servo motor, wire the power to "+", ground to "-", and the signal on row 30 in the breadboard. After, you wire the signal from the bread board to pin 8
- For the Ultrasonic Sensor, place it between rows 16-19. Wire the power to "+", ground to "-", echo sensor to pin 5, and trigger sensor to pin 6.
- For the motor driver, connect it on column "d" and "h" between rows 22-29. Make sure PWMA is on column "h" row 22.
- Wire "PWMA" to pin 11, Input 2 to pin 13, Input 1 to pin 12, "STBY" to "+", Input 4 to pin 10, Input 3 to pin 9, "PWMB" to pin 3, "GND" to "-", "VM" and "VCC" to "+".
- Wire the first gear motor to "B02" and "B01", and the second to "A01" and "A02".
Step 2: Arduino Code and Flow Chart
Down below is the code for the breadboard. Open in Arduino and upload it using a USB cable to the breadboard. Above is the flowchart on the code is supposed to work.
Step 3: Physical Construnction
- Make a box frame with carboard and tape.
- Cut it an opening for the sensor and power port for the battery pack.
- Grab a funnel and cut off the end. Attach the end of the funnel to another funnel at an angle to create a path for the seeds.
- Attach this on the top of the box frame with tape.
- At the end of the funnel, create a hole in which would be used to block the seeds from falling.
- Attach the gift card to the servo and adjust it in a way for the gift card to block the opening.
- Attach a battery pack on the back side of the box frame.
- Attach wheels to the gear motors and connect it underneath the board.
- On the back of the board create a stand made of cardboard and tape.
- Place the box frame on top of the board and make sure the sensor is not covered up.
- Make sure everything is secured and taped correctly.
Step 4: Video
This is a video of the Seed Sower working
