Introduction: Self Balancing Segway Instructabot
Supplies:
1. Arduino: I used an Uno
2. 7.2v battery
3. Set of motors: Parralax's 7.2v motor set http://www.robotshop.com/parallax-7-2v-motor-bracket-wheel-kit-pair.html
4. Analog accelerometer http://www.robotshop.com/sfe-3g-tripleaxis-accelerometer-breakout-board-adxl335-2.html
5. Sabertooth 5X2 motor controller http://www.robotshop.com/productinfo.aspx?pc=RB-Dim-19&lang=en-US
6. base board
7. 3/4" threaded rod and nuts for balance
8. Zip ties
9. Screws
Tools:
1. Drill
2. 3/4" and 1/4" drill bits
Step 1: Instructabot Platform
I used a piece of wood 6" x 12" x 0.5"
Step 2: Electronics
Now for the electronics...
The brain of the robot is an Arduino UNO which reads the accelerometer and gives commands to the motor controller which in turn powers the motors. The Arduino takes 10 readings per second from the accelerometer and proportionally changes the motor speed and direction. The Arduino code has gone through many changes and tests, but you still may have to change some of the values to be compatible with your robot. To run the robot, hook up all the wires in the correct fashion and upload the code below to the Arduino. It should start working right there and then.
//Self Balancing Instructabot 2013
//Ferris
#include
int x, r, l, s, f, xa, xb, xc;
//Digital pin 13 is serial transmit pin to sabertooth
#define SABER_TX_PIN 13
//Not used but still initialised, Digital pin 12 is serial receive from Sabertooth
#define SABER_RX_PIN 12
//set baudrate to match sabertooth dip settings
#define SABER_BAUDRATE 9600
SoftwareSerial SaberSerial = SoftwareSerial (SABER_RX_PIN, SABER_TX_PIN );
void initSabertooth (void) {
//communicate with sabertooth
pinMode ( SABER_TX_PIN, OUTPUT );
SaberSerial.begin( SABER_BAUDRATE );
void setup() // run once, when the sketch starts
initSabertooth();
//analogINPUTS
Serial.begin(9600);
void set_motor() {
x = analogRead(0); // read analog input pin 0
//x range is about 270-400 and flat is about 330
//smooth x by averaging 3 readings of x
xa = x;
delay (20);
x = analogRead(0);
xb = x;
delay (20);
x = analogRead(0);
xc = x;
x= (xa +xb + xc)/3;
//SABER_right_FULL_FORWARD 127
//SABER_right_FULL_REVERSE 1
//SABER_left_FULL_FORWARD 255
//SABER_left_FULL_REVERSE 128
//s=slope with less being more aggressive
s = 1.8 ;
//f=fudge factor
f = 5;
//stable x around 330
if ((x > 325) && (x < 335)) {
r = 62;
l = 194;
//drive forward at a steady speed if leaning forward a little 310 > x < 330
if ((x > 310) && (x < 326)) {
r = 45;
l = 167;
//if falling forward more increase speed linearly for 279 > x < 311
if ((x > 279) && (x < 311)) {
//higher values make it faster
r = s * x - 278 + f;
l = s * x - 148 + f;
//if full forward x < 280
if ((x > 250) && (x < 280)) {
r = 6;
l = 133;
// drive backward at a steady speed if leaning back a little 334 > x > 349
if ((x > 334) && (x < 349)) {
r = 78;
l = 208;
//if falling backwords more increase speed linearly for 348 < x < 390
if ((x > 348) && (x < 391)) {
//lower values make it faster
r = s * x - 270 + f;
l = s * x - 140 + f;
//if full backwords 390 < x
if ((x > 390) && (x < 410)) {
r = 122;
l = 250;
//send motor outputs to sabertooth
SaberSerial.write(byte(r));
SaberSerial.write(byte(l));
void loop () {
float level = 0;
int u;
set_motor();
} // end loop
Step 3: Making the Instructabot
So now it's time for the artistic part of this make.
Supplies:
1. Cardboard
2. Glue
3. Robot print
Tools:
1. Scissors
Step 4:
What did you make?
I made a self-balancing, segway-like robot. The robot works by taking readings from the accelerometer in the x-direction, converting them to digital, then putting them into a formula which turns the motors a specific speed to get it to right itself.
How did you make it?
I have wanted for some time to make a full size ride-on segway but decided to start out with a smaller version to get some ideas for a full-scale version. To make it, I used a drill, soldering iron, computer for programming the Arduino, accelerometer, motor controller, screwdriver, and a lot of ingenuity.
Where did you make it?
I made the entire robot at home.
What did you learn?
Before this project, I hadn't done a lot of stuff with accelerometers so this project gave me a great oppurtunity to learn about them. Also, sending serial to the motor controller took some thinking and tinkering with the computer program which was challenging. I was most proud of getting it to balance. The biggest surprise was how hard it was to get the code just right.
Make-to-Learn Youth Contest
Jury Rig It! Contest
83 Discussions
3 years ago
very helpful! sir i want to know details about the wheels. please help me since i am very much interested in this as my project
3 years ago
could this hold the weight of a person that weights 100-110 pounds
4 years ago
In the video it says "with a leash". I thought after trying to balance itself for 10-15 seconds it goes 1-2 metres forward, then it comes backwards. Am I wrong?How does it do it in the video?
Thank you by the way.
4 years ago
Hi. Could you show me which part of the code makes the robot go forward( for a certain distance) then go backward (for a certain distance as shown in the video) please? Thank you.
Reply 4 years ago
The code given makes the robot try to stand up straight. When it falls forward it tries to right itself and moves forward in the process.
Reply 4 years ago
Reply 4 years ago
4 years ago
great job! Do check out this nano segway :
https://www.instructables.com/id/Arduino-Nano-Segwa...
7 years ago on Introduction
Hi again, Can you tell me the max + and - angle from the vertical you based your code on? I'm still having difficulty in smoothing out the motion. Thanks
Reply 4 years ago
Hi there! Can you help me with my masters degree project connected with Segway problem? I want to use neyral networks and fuzzy logic in it. I only have an arduino and a driver for 2 motors based on L298D chip
Reply 4 years ago
hello Librav nice robot you have here can you please send me the code and the design for your project to
ahmedmerzoug7@gmail.com
Reply 6 years ago on Introduction
Wow....that's awsome segway!
Nice job on this. Which wheels sets are you using?
Your bot looks great. The max my accelerometer measured while on the segway was 400 and the minimum was 270 with 330 about flat
5 years ago on Introduction
it was awesome but the arduino uno is showing errorketch_may27a:21: error: expected unqualified-id before '\x616c'
sketch_may27a.ino: In function 'void initSabertooth()':
sketch_may27a:26: error: 'SaberSerial' was not declared in this scope
sketch_may27a.ino: In function 'void setup()':
sketch_may27a:29: error: redefinition of 'void setup()'
sketch_may27a:1: error: 'void setup()' previously defined here
sketch_may27a.ino: In function 'void set_motor()':
sketch_may27a:102: error: 'SaberSerial' was not declared in this scope
sketch_may27a.ino: In function 'void loop()':
sketch_may27a:107: error: redefinition of 'void loop()'
sketch_may27a:6: error: 'void loop()' previously defined here
so can you help me for solving it
aesome . but i have got a problem that a have not got the sabertooth motor controller anywhere so can i use l298 p
Awesome. I'm doing segway and trying optimal trajectory problem. I was wondering for your RF control what kind of receiver you used. Or anyone use a specific type of receiver?
is possible with mma7361 or gy-521 acclerometer ?
5 years ago on Step 2
HELLO i have one question i tried to use your program and i couldn´t do it sorry i´m new in this topic :'( but i would like to do that amaizing robot =D can you help me :( please I´ll be very glad with you for the rest of my life =D
Where is schema of the accellerometer and arduino??
