Introduction: Self Laminating
About: My name is Chooch and I like sports and finding creative things to do with household items
For this you will all you will need is: Scissors - tape - and a few sheet protectors. If you have any problems (which you should not) Feel free to contact me. Also if you like this don't forget to love it and drop a follow. Enjoy!
Step 1: Cutting the Sheet Protectors.
For this step all you will need are your sheet protectors and scissors. Locate the three sides of the protector that are connected and cut them all the way through. Once you have cut all three sides then pull the pieces apart so you have two pieces.
Step 2: Taping Your Peices
For this step you will need your halves of the sheet protector and tape. Lay the sheet protector on a corner of the piece of paper. Make sure your tape is fully covering all of the openings between the paper and the protector or else it will fail. Tip: When you secure the bottom of the protector to your sheet of paper make sure to use small pieces of tape to make it easier.
Step 3: Now Do It All Over!!! YAY
Now depending on the size of your paper you probably will need to do it again. Have Fun!!!!!
