Introduction: Self Retracting Box Cutter Using Rubber Band
Just turn your box cutter into Self Retracting Box Cutter Using Rubber Band
-> your usual Box Cutter
-> Rubber band (I used a 20 milimeters diameter)
->Universal pliers (or tweezers)
->Something to help you reach small pieces ( I used a small screwdriver)
Step 1: Dismantle the Box Cutter
Simply remove the bottom and center piece and remove the blade, as shown in the pictures
Step 2: Disassemble the Centerpiece
Disassemble the centerpiece and remove the metal parts that secure it
Step 3: Place the Rubber Band
Place the Rubberband so that the center piece is attached in some way (you can use glue)
Step 4: Assemble the Box Cutter
Assemble the box cutter, making sure that the Rubber Band is stuck somewhere, I used the bottom part to pin it so that it is stuck.
