Introduction: Self Watering Pot
So this project is very easy going and equally useful. Anyone with a little or negligible knowledge about Arduino can also successfully make this project
You Will Need
Arduino UNO (microcontroller)
Its Data Cable
Soil moisture sensor
few jumper cables
5v water pump submersible with tubings
Water tank/small box
1 channel 5v relay module
And Arduino IDE
Step 1: Understand the Code
In this project code is very short and sweet and pretty much self explanatory
Step 2: Connect All Pins Correctly
Connections:
connect the Sensor's A0 pin with Arduino's A0 pin
connect VCC of sensor with Arduino's 3v3 pin
connect VCC of relay with Arduino's 5v pin
connect Realy's signal pin to D13 of Arduino
connect gnd of relay and sensor with Arduino
Connection of relay and pump:
connect +ve of cell to common port of relay and +ve of pump with NO port
connect -ve of cell and pump dirrectly
Step 3: Hurray...! Project Completed
Now tune the sensor 'limit' value to get optimum results
