Introduction: SelfCAD 3D Cabinet
In This tutorial we can learn how to create 3d cabinet in selfcad with some basic command line extrusion, insert, and add details, Check it out!!!
Step 1: Creating Top and Bottom Base
> First drop and drag cube objek
> Use face selection and select on the top face. Use move tools to move in green axis
> After it we can use extrusion tools, to extrude with amount 5
> Next you can select all side face, and extrude again with individual and connect neighbors.
For the bottom
> Deselect face selection
> Click modify > add details. Select from top and hold, move to the bottom. It will be create new edges (make sure automatic loop finding active
> Do the same steps, to extrude all faces
Step 2: Editing Top Face
> Use face selection > and select at front face
> Click modify > insert and give amount 3
> Next you can press ctrl button (hold) > move drop and drag to the right
> After it select 3d model object, click modify > add detail. And you can create 3 new edges
Step 3: Create Hole
> Use face selection and select front face
> Click modify > insert > active individual and give amount 1
> Click modify > extrusion > and move to back, so it will be create hole
Step 4: Creating Door
> Select Surface object. Use edge editing, and select all edges
> Click utilities > Snaps > and click on bottom in front 3d model, to move the surface
> Next you can use rotate with specific gizmo location
> Afterit we can use add thickness with amount 3
