Introduction: SelfCAD 3D T Pipe Tutorial
Today we can learn how to create 3D T pipe in selfcad by using basi command
Step 1: Creating 2 Cylinder Object
- You can create 2 cylinder object by drag and drop into drawing window
- Next you can rotate one cylinder object into vertical and move to center of the other cylinder
- You can use scale tools to scale vertical cylinder
Step 2: Make Hole
- First we need to combine all object by using union command
- After it you can use polygon options to select 3 face of the object, and then delete it
- Finally we can use add thickness to make object into 3d solid
Step 3: Creating Cylinder
- In this steps we can create cylinder object again
- Next you can select top and bottom of cylinder, after it we can use add thickness to convert into 3d solid
- Use move tools to move cylinder object into every face T Pipe
Step 4: Video Tutorial SelfCAD 3D T Pipe
Watch video tutorial how to create 3d T Pipe with selfcad
