Introduction: Sequin Pasties
Pasties are nipple coverings that are used for flirting and teasing. Initially they were mainly used in clubs and strip joints, but now a days they can be found in the bedrooms of ordinary women.
The purpose of wearing pasties is to expose as much of the breast possible without being entirely topless.
Pasties make a great sexy gift.
They are a fun way to spice things up in the bedroom.
Step 1: Materials
sequin trim
2 tassels
double sided tape
glue dots
foam
scissors
pen
scrap paper
a glass or anything that will allow you to trace a circle
Note: you could try using super glue or any other kind of adhesive, I just find that it is much easier and less messy to work with double sided tape and glue dots.
Step 2: Making the Pattern
♦ Place the glass upside down on the scrap piece of paper.
♦ With the pen trace the circle around the glass ( you will need a bigger circle if you are a large cup zise).
♦ Cut out the circle.
♦ Fold the circle in half.
♦ Fold it in half one more time.
♦ Open it up and cut a slit right up to the middle of the circle.
Step 3: Making the Base
♦ Using the pattern, trace two circles on the foam and draw a line on the foam circle where the slit is suppose to be.
♦ Cut the foam circles and cut a long the straight line to create the slit.
♦ Place a glue dot on one corner of the edge of the circle and the slit, apply a second glue dot just above the first one.
♦ Attatch a tassel by placing the tassel's hanging string over the glue dots. Ensure that the end of the string alines with the edge of the circle.
♦ Place another 2 glue dots on top of the tassel's string.
♦ Grab the other edge of the cut circle and pull it over the area with the glue dots and tassel so that it over-laps and creates the desired curvature. Press down firmly.
♦ Double check that the pasty will be the right size by placing it over a nipple. If it's too big cut around the edge to make it the decired size. If too small, you'll need to start over from step 2.
Step 4: Applying the Sequin
♦ Cover the surface of the base with double sided tape. Apply one strip of tape then pill it off before applying the next piece. It's ok for the tape to over-lap. Ensure the entire surface is covered.
♦ Apply the sequin starting at the bottom, go around in circles pressing down firmly making sure it's sticking to the base.
♦ Once you reach the top, cut the eccess sequin. If you're having problems getting the end of the sequin to attach peal off some of it and apply a glue dot to the tip of the base and reattach the sequin.
♦ Use double sided tape on the inside of the pasties to adher them to the breasts.
