Introduction: Servo Control With NodeMCU and Blynk | in IOT Platform
In this tutorial you can control your servo using Blynk app in IOT Platform
Step 1:
In this project you have to need Hardware
1. Nodemcu
2.Servo
3.connection ware
Software
1. Ardunio
2. Blynk App
This tutorial i divided into 4 Part
Part 1: NodeMCU insulation with wifi name and password
char ssid [] = "Your WIFI name";
char pass [] = "Password ";
Explain: Include the Wifi library and wifi name and password that you went to be use for internet
Part 2: Blynk App Option
#include
#define BLYNK_PRINT Serial
char auth [] = "yourAuthkey ";
Explain: Include the blynk app library and reflex your auth key from you gmail
Part 3: Servo operation
#include servo.h
Servo servo1;
#define servo1Pin D2
Explain: Include the servo library and Create the Servo and name it "servo1" and Define the NodeMCU pin to attach the Servo
servo1.attach(servo1Pin);
Explain: NodeMCU (A0) from 0 to 3.3V. Internally, the 10 bits ADC (Analog-Digital converter) will generate a digital value (from 0 to 1023),
servo1Angle = map(PotReading, 0, 1023, 0, 180);
Explain: We should "map" this digital value, in order that the Pulse Width Modulated (PWM) digital output of pin D2, will vary from 0 to 180 (servo1Angle). and With this signal, the servo will turn from 0 to 180 degree, using the bellow command.
Step 2: Part 4: Creating a Blynk App to Control the Servo Flowing Image
Downlode Code Click Here
1.Intoduction to nodemcu8266 & Steps to Import ESP Board Libraries
2.NodeMCU8266 Basic Project-Blink a LED
3.NodeMCU8266 Digital Read (Push Button)
4.Analog Data read using NodeMcu8266
5. NodeMcu LED control Use in Blynk app in IOT platform
6.NodeMcu to DHT Interface in Blynk app| On IOT Platform
7.The Best Way To nodemcu gps tracker blynk app |in IOT platform
