Introduction: Servo Gladiators
In this project we put two potentiometers in two breadboards to control servo motors. The servo motors will fight to the death!!!!!!
***This project is just a prototype. We are looking to make a bigger one with a bigger servo motor. We are still working on the code.
Step 1: Materials
Arduino
2 breadboards
2 potentiometers
2 servo motors
20 wires
Power supply ac/dc adapter
Step 2: Servo Motor
*** When you are doing this project keep this picture in mind.
https://www.google.com/search?q=servo+motor+arduino&rlz=1C5CHFA_enUS718US718&source=lnms&tbm=isch&sa=X&ved=0ahUKEwj1ks7C7LrYAhXpSN8KHX-HBGYQ_AUICigB&biw=1229&bih=981&dpr=1.25#imgrc=Tcc2IFNkUH95_M:
Step 3: Code
#include < Servo.h >
Servo myservo; // create servo object to control a servo Servo myservo1;
int potpin = 0; // analog pin used to connect the potentiometer
int val= 0;// variable to read the value from the analog pin
int potpin2=A2;
int val2=0;
void setup() {
myservo.attach(9); // attaches the servo on pin 9 to the servo object
myservo1.attach(10); pinMode(potpin,INPUT);
pinMode(potpin2,INPUT);
Serial.begin(9600); }
void loop(); {
val = analogRead(potpin);
val2 = analogRead(potpin2); // reads the value of the potentiometer (value between 0 and 1023)
val = map(val, 0, 1023, 0, 180);// scale it to use it with the servo (value between 0 and 180)
val2 = map(val2, 0, 1023, 0, 180);
Serial.println (val);
Serial.print (val2);
myservo.write(val);
myservo1.write(val2); // sets the servo position according to the scaled value
delay(10); // waits for the servo to get there }
Step 4: Steps:
1.) place the two petentiometers in seperate breadboards.
2.) Place the pins in back of it.
1st petentiometer:
left pin goes to minus
middle pin goes to A0
Right pin goes to plus.
2nd petentiometer:
left pin goes to plus on the other breadboard.
middle pin goes to a2 in the arduino.
right pin goes to minus in the other arduino.
1st Servo motor:
Brown goes to ground
Red goes to plus
Orange goes to pin in the arduino. we used d10.
2nd servo motor
Red goes to plus
Orange goes to pin. We used d9
Step 5: Pictures:
Optional: You can add swords to the ends.
By: Justin Herskowitz and Ian Friedman
