Introduction: Setting Up a Vnc Server (Raspbian)
This is a beginner level project for anyone who may want to utilize the full power of the raspbian Graphical environment without having to spare a separate monitor, mouse or keyboard.
As this is a beginner project I will try my level best to make it easily understandable and follow-able.
the bash script is indented so that it is easy to pick out
But since this is my first instructable I would highly appreciate any critical review of the instructable in the comments. :)
Step 1: Apparatus Required
1. Raspberry pi 2(It might work for 1 but i tested it on 2)
2.Ethernet cable / compatible WiFi dongle
3.Power supply for the raspberry pi(micro-usb)
4. SD card configured with raspbian os (https://www.raspberrypi.org/downloads/raspbian/ )
5.A windows computer (i have not worked with a mac so can't tell you how it works there)
last but not the least,as for any project big or small, patience and resilience to failure.
Step 2: Software Required
1. tightvnc ( http://www.tightvnc.com/download/2.7.10/tightvnc-2... )
you can use any other vnc viewer but i will be using this one.
2.putty for ssh-ing into the pi (if u can't use external monitor and perpherals)( http://the.earth.li/~sgtatham/putty/latest/x86/putty.exe )
Step 3: Pre-requisites
1.A fully configured network connection(basically internet for pi) with static IP for the pi
2.Raspbian OS
3.knowledge of ssh on raspberry pi if u do not have a monitor to spare.
if u have a problem achieving any of these let me know and i shall try to make tutorials on that too.
Step 4: Setting the Pi Up
ssh into the pi or open terminal in raspbian os
type the following code
sudo apt-get install tightvncserver
this will download vnc server for pi .Press 'y' when it prompts for install
then type
tightvncserver
setup up the server with password (keep the pass the same as that of your pi and help your memory out)
then type
vncserver :0
now u have opened up port 0 for vnc purposes
Step 5: Access From Computer
open tightvnc viewer and enter the IP address of your pi followed by :(colon) and then the port number
if u followed this instructable then the port number is 0.
login as pi( if default ,if u changed it then u know enough to know what to type ;)
the password is the one u set up in the last step.
if all goes well u officially have VNC access to the pi
Step 6: Now to Teach the Pi to Do This Automatically
now that u have vnc access I suggest u open this webpage inside the pi since there is a LOT of bash script if u are copying the code
Create a file containing the following shell script (use leafpad if nano scares you):
#!/bin/sh
vncserver :0 -geometry 1920x1080 -depth 24 -dpi 96
Save this as vnc.sh (for example)
to make the file executable:
chmod +x <file path of vnc.sh>
Then you can run it at any time with:.
/vnc.sh
Step 7: To Run This at Boot
to log into a terminal on the Pi as root:
sudo su
then navigate to the directory /etc/init.d/:
cd /etc/init.d/
to create a new file here using nano:
nano vncboot
this opens up the nano ui
open the file vncboot.txt and copy everything to the nano ui
press ^X(Ctrl + x) to exit
press 'y' to save the file
this saves the file as vncboot.
to make this file executable:
chmod 755 vncboot
to enable dependency-based boot sequencing(to put the file in the boot file:
update-rc.d /etc/init.d/vncboot defaults
If enabling dependency-based boot sequencing was successful, you will see this:
update-rc.d: using dependency based boot sequencing
But if you see this:
update-rc.d: error: unable to read /etc/init.d//etc/init.d/vncboot
then try the following command:
update-rc.d vncboot defaults
This should complete your vnc setup.
Reboot your Raspberry Pi and and you should find a VNC server already started.
Step 8: Test
if it didn't just comment your problem
we will try to fix it together!!!
Step 9: This the End
thank for your time and patience for going through this complete instructable
i hope this was beneficial to you or at least that i didn't bore you.
a bonis ad meliora
