Introduction: Setup Raspberry Pi Using Diet Pi Without Monitor or Keyboard
This instructable is deprecated. Please use: DietPi Setup
NOOBS requires a monitor, keyboard and mouse, which adds ~$60 (USD) or more in cost. However, once Wi-Fi is working, these devices are no longer needed. Perhaps, DietPi will support USB to serial in the image.
Every time I start a new Raspberry Pi project, I lug out the monitor, keyboard and mouse and find a place to set them up. After completing my third Raspberry Pi project, I thought there must be a better way.
This approach is a bit more advanced and uses a MacBook Pro instead of a monitor, keyboard and mouse. So, it saves $45 and takes up less space.
With this instructable, I've started using Diet Pi instead of Raspbian. Most of my projects are headless. Using Diet Pi provides longer SD card life and reduces overhead processes, thereby increasing performance.
The first pass requires a keyboard, monitor and mouse. The second pass eliminates the need for these.
The goals of this project are to:
- Use Diet Pi
- Eliminate the need for a monitor, keyboard and mouse on subsequent setups
- Create a standard micro SD card image so next time I can skip many of the steps
- Compress the micro SD card image
Step 1: Gather Parts
I have found the parts below perform best in my applications. These parts are more expensive than those contained in the usual starter kit.
Get parts and tools (prices in USD):
- MacBook Pro (a PC could be used)
- Raspberry Pi 3 or Raspberry Pi 2 Model B Element14 $35
- Panda 300n WiFi Adapter Amazon $16.99
- 5.2V 2.1A USB Power Adapter from Amazon $5.99
- Micro USB to USB cable 3ft from Amazon $4.69
- FTDI TTL-232R-RPI Serial to USB cable from Mouser $15
- Case from Amazon $6.99
- SanDisk Ultra 16 GB microSDHC Class 10 with Adapter (SDSQUAN-016G-G4A) from Amazon $8.99
- TV with HDMI port, USB keyboard, USB mouse, HDMI Cable (only needed on first pass)
Notes:
- Text enclosed in spades, such as, ♣replace-this♣, should be replaced with an actual value. Of course, remove the spades.
Step 2: Download Diet Pi
Compared to a laptop or desktop PC, the raspberry pi's processor is underpowered. So, a dominant principle in getting acceptable performance is to eliminate unnecessary load on the processor.
Diet-Pi is a minimal installation of raspbian. Diet-Pi eliminates operating system processes that are not required allowing the processor to perform user tasks more quickly. Running the command top on one of my raspbian systems shows 126 tasks running, while diet-pi only has 91.
Diet-Pi also has a lightweight GUI and eliminates unnecessary I/O to the micro SD card. SD Cards get worn out after repeated write cycles. Reducing the number of writes, prolongs the life of the SD card. Most of my projects don't require a GUI. So, in a later step, LDXE is removed.
DietPi writes most logs to a RAM disk saving writes to the micro SD card.
Steps:
- Download the latest version from here Diet-Pi. Go to Download. Select Raspberry Pi. Select Raspberry Pi All Models. And then select Download Image.
- When this was updated the latest version was: DietPi_v6.0_RPi-ARMv6-Stretch
- Once it is downloaded, drag the download from download to a directory where you store images. I like to keep downloaded images and backup images of raspberry pi projects in a directory on my Mac.
- Remember anything enclosed in ♣'s is replaced by your name or value
♣macbook-image-directory♣
- Open a terminal window on the MacBook
- Change to your image directory and list the files
$ cd ♣macbook-image-directory♣ $ ls 2015-11-21-raspbian-jessie.img SDCardBackupSetup.dmg DietPi_RPi-(Jessie).7z disk_test.dmg
- I used unarchiver to decompress the zip file (.7z) on my MacBook.
- And then deleted the compressed file (drag the zip file to the trash)
$ cd ♣macbook-image-directory♣ $ ls 2015-11-21-raspbian-jessie.img SDCardBackupSetup.dmg DietPi_v136_RPi-(Jessie).img disk_test.dmg
- If the image name contains parentheses, later steps won't like that. So, rename the file and remove the parentheses. The image is now: ♣diet-pi-image♣
Step 3: Burn Diet-pi Image to Micro SD Card
Download etcher from here, and then install etcher. Etcher makes installation fool proof.
Start etcher
- Select your image ♣diet-pi-image♣:
- Select your microSD card
- Flash
- Enter MacBook password
For whatever reason, etcher does not unmount the microSD card. So, I need to select the drive and then right click to Eject it (or if one button mouse CTRL-click). If you don't eject it doesn't really matter, you will get a warning message.
Step 4: Raspberry Pi Setup and Connections
Heat Sink
Remove tape and press firmly on to processor. The heat sink and chip are almost the same size. It was fairly obvious were it was supposed to go. I did not take a picture.
Case
Take case apart. The older version has three parts: top, bottom and middle. Slide Raspberry Pi into bottom part of case Slide Raspberry Pi into bottom. There are two clips on the end where the SD card is inserted. The board must slide under these clips. It slides in easily, no need to force it. Again, this seemed very straightforward. So, there is no photo. It is good to keep the pi in the bottom part of the case.
Cables and SD Card
Unless indicated, insert the following into Raspberry Pi
- Only needed for Pass 1
- HDMI cable to a TV
- USB Keyboard
- USB Mouse
- Micro SD card
- Ethernet cable
- Wi-Fi dongle
- USB serial I/O cable (see images above)
- Ground = Black wire, pin 06 on RPi
- Tx = Yellow wire, pin 08
- Rx = Red wire, pin10
Once the above are complete:
- Insert power cable
Insert USB/Serial cable into MacBook USB port
If using a myDietPi_v104_RPi-jessie.img created in Pass 1, then
- Check the appendices to see if there are any optional steps you would like to add
- Run dietpi-config to change the hostname
- After changing the hostname, you might need to remove an RSA Key. The instructions to do this are in the appendix to this instructable.
- You are done!
Step 5: Set Up DietPi
Set up DietPi.
Login to raspberry pi
login: root password: dietpi
Follow the directions. DietPi will update and install necessary software.
Step 6: Configure DietPi
Login when prompted to do so.
Instead of about 25 setup screens, I used the menu numbers as a guide.
If presented with a menu, then navigate through the menu using:
- arrow keys
- tab to move
- space to toggle options from space to *
- and ENTER
Follow the directions, it is easy to use. Some steps will require a restart. Go through all the menu options and decide what you want.
If you mess up, it's no big deal. Just start over.
Here is my setup. Change to suit your needs.
DietPi-Software
The first menu is DietPi-Software
Select dietpi-config.
Main Menu
- Display Options
- Audio Options
- Performance Options
- Advanced Options
- Language/Regional Options
- Locale (for the US use space bar to make *)
- [*] en.US.UTF-8 UTF-8
- en.US.UTF-8 - default locale
- will generate changes
- Timezone
- US
- Central
- Keyboard
- Other
- English (US)
- No compose key
- Default for keyboard layout
- Model: Dell
- Other
- Security Options
- Change Root Password
- Change Hostname
- Networking Options
- AutoStart Options
- 0. Console: Manual Login (default)
- Tools
and then reboot.
Login with root and ♣your-password♣
DietPi-Software
Install optional software.
DietPi Software Setup menu:
- Select DietPi Optimized Software
- [*] RPi.GPIO
- [*] LLSP: lighttpd | sqlite | php NOTE: this is optional
- [*] certbot - NOTE: As of 16APR2018 certbot does not work with lighttpd
- Select Software Additional Linux
- [*] Python pip NOTE: this is optional, but most of my projects use python
- [*] Avahi-daemon
- SSH Server: change from DropBear to OpenSSH
- File Server : None
- Log System: DietPi-Ramlog #1
- Help!
- Go Start Install
DietPi will install the software
Step 7: Optional: Setup Wi-Fi
In general, Raspberry Pi can use either a wired or wireless connection.
If you want to use Wi-Fi, then unplug ethernet cable and enable Wi-Fi
Login and run dietpi-launcher.
$ dietpi-launcher
The menu looks something like this:
- DietPi-Software
- DietPi-Config
- DietPi-AutoStart
- DietPi-Cron
Select DietPi-Config, which looks something like:
- Display Options
- Audio Options
- Advanced Options
- Security Options
- Network Options: Adapters
Select Network Options: Adapters
- Select WiFi - enable WiFi
- Select Onboard WiFi - enable onboard Wi-Fi
Select Network Options: Adapters and then WiFi
Select Scan and Connect, choose your home's SSID
Change Country: US
Enable Auto Reconnect
Enter your password (aka Access Key): ♣your-home-ssid♣
Apply changes
After reboot, DietPi will show:
IP eth0: ♣your-ip-address♣
Open a terminal window on your computer and see if you can connect wirelessly to the Raspberry Pi using one of the commands below.
$ ssh root@♣ip-address♣ $ ssh root@♣your-hostname♣.local
And WiFi should work.
Step 8: Add User Pi to DietPi
By default, DietPi uses a login of username: root, while raspbian uses username: pi.
Many Raspberry Pi directions and my instructables assume a starting point of /home/pi and a login of pi. So, add a user called: pi
$ useradd pi -m -G sudo $ passwd pi Password: ♣raspberry-pi-password♣ Password: ♣raspberry-pi-password♣
If you make a mistake, use the following command to remove the user:
$ userdel pi
Make a copy of the file /etc/sudoers
As user, root, edit the file, but be careful with this file. Be sure it correct before saving
$ sudo nano /etc/sudoers
Without the following change you will have to enter a password each time sudo is used.
After the comment, #includedir ..., add the line that starts, pi ALL=:
#includedir /etc/sudoers.d pi ALL=(ALL) NOPASSWD: ALL
CTRL-o, ENTER, CTRL-x to save and close the file
Add bash shell, using
$ sudo nano /etc/passwd
and edit user pi to add /bin/bash at the end. Don't change anything else:
pi:x:1001:1001::/home/pi:/bin/bash
Check the new user works
$ logout
and login as pi with ♣raspberry-pi-password♣
$ ssh pi@♣ip-address♣
If logged in as pi, DietPi utilities are located in:
/DietPi/dietpi
dietpi scripts use a check for root UID = 0, which prevents the pi username from running the dietpi scripts. The script checks if $UID=0, which should be reserved for username root. Adding the directory to PATH doesn't help.
So to run dietpi-config or any of the dietpi utilities from pi, login as super user, and then run the command. To exit superuser, enter exit.
$ sudo su $ sudo /DietPi/dietpi/dietpi-config ♣change-settings♣ $ exit
Of course, you could modify the script and add the pi username's UID or remove the check for root's UID. There might be additional changes required.
if (( $UID != 0 )); then
Optional Step
In general, root should not be used as a login. The root login should not be disabled, but should be blocked from normal login.
To prevent users from logging in directly as root, set the root account's shell to /sbin/nologin in the /etc/passwd file.
Change
root:x:0:0:root:/root:/bin/bash
to
root:x:0:0:root:/root:/usr/sbin/nologin
Step 9: Get FTDI USB to Serial Interface Working
By default, DietPi has usb to serial disabled. Enable this service so we can use it in the future.
$ sudo nano /boot/cmdline.txt
In the file, add before console=tty1
console=ttyAMA0,115200
CTRL-o, ENTER, CTRL-x to save the file and exit
Enable the service and restart the Raspberry Pi
$ sudo systemctl enable serial-getty@ttyAMA0.service $ sudo reboot -h 0
If not plugged-in, plug-in the FTDI USB to serial cable
USB serial I/O cable (see image above). The outer corner of the Raspberry Pi has pin 2. The outer row closest to the edge are even numbered pins (2, 4, 6), and the inner row are odd numbered
Step 10: Determine USB Port
Determine USB Port being used by USB-Serial adapter. My MacBook uses a chip from FTDI.
Open terminal window on MacBook
There are a lot of devices in /dev. Use this command to identify the device (in this case, it is FT9314WH):
$ ls /dev/tty.*<br>/dev/tty.Bluetooth-Incoming-Port /dev/tty.usbserial-FT9314WH
Here is an alternate way to discover:
$ ls /dev | grep FT | grep tty tty.usbserial-FT9314WH
If neither of the above work, then try this:
Insert USB cable into MacBook, and run:
$ ls /dev | grep tty
Unplug USB cable, wait a few seconds and run:
Identify the differences
Step 11: Open Terminal Window and Connect to Raspberry Pi
Open (or continue using) terminal window on MacBook.
See the image above and set up the terminal window preferences.
- Terminal, select Preferences, click Advanced tab
- xterm and vt100 work, but ansi works better when using nano
- Set Western ASCII instead of unicode (UTF-8))
In a terminal window enter:
$ screen /dev/tty.usbserial-FT9314WH 115200
Using terminal window on MacBook, login in to RPi: username = pi password = raspberry
Note: the USB-serial cable can drop characters. If characters are dropped you may not get a prompt, press Return or enter username and press Enter.
If recovery mode appears, then micro SD card is not set up correctly. Start over.
- Diet Pi's prompt for root user # (on raspbian recovery mode uses a # prompt)
- Diet Pi's normal prompt for pi user is $
Step 12: Always Update and Upgrade
Always update and upgrade.
- "apt-get update" downloads latest package lists from appropriate repositories.
- "apt-get upgrade" updates the packages
- "apt-get autoremove" deletes packages that are no longer needed
- Reboot is optional. Some services need to be restarted after an upgrade. Rebooting is my lazy way of ensuring all required services are properly restarted
Run the following commands:
$ sudo apt-get update $ sudo apt-get upgrade $ sudo apt-get autoremove $ sudo reboot
If there are errors, check that an Ethernet cable is plugged in.
Step 13: Expand File System
raspi-config contains an option to expand the file system to use the whole micro SD card. I was concerned expanding the filesystem was overlooked in dietpi-config.
However, by default, "DietPi images come pre-optimized with features like automatic file system expansion."
To show the file system is expanded, run the command:
$ df -h
On DietPi, there is no need to expand the file system.
Step 14: Optional: Remove GUI
Optional step. My projects don't use a GUI, so remove it. Removing the GUI saves about 2MB of storage and improves performance.
$ sudo apt-get --purge remove 'x11-*' $ sudo apt-get --purge autoremove
Adding turbo mode has some wifi performance benefits. Edit the file:
And add
smsc95xx.turbo_mode=Y, so it looks like:
dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes smsc95xx.turbo_mode=Y rootwait rootdelay=10
CTRL-o, ENTER, CTRL-x to save and exit
Then reboot
$ sudo reboot<br>
Step 15: Setup Gmail
Mail is very useful for receiving notifications and alerts about issues on the Raspberry Pi.
Ensure repositories are up-to-date. Run the command:
Install SSMTP and mail utilities:
$ sudo apt-get install ssmtp $ sudo apt-get install mailutils -y
Edit the SSMTP configuration file:
$ sudo nano /etc/ssmtp/ssmtp.conf
as follows:
root=♣your-gmail-account♣@gmail.com mailhub=smtp.gmail.com:587 hostname=♣your-hostname♣ AuthUser=♣your-gmail-account♣@gmail.com AuthPass=♣your-gmail-password♣ UseSTARTTLS=YES
Edit the SSMTP aliases file:
$ sudo nano /etc/ssmtp/revaliases
Create one line for each user in your system that will be able to send emails. For example:
root:♣your-gmail-account♣@gmail.com:smtp.gmail.com:587 <p>pi:♣your-gmail-account♣@gmail.com:smtp.gmail.com:587</p>
Set the permissions of the SSMTP configuration file:
$ sudo chmod 664 /etc/ssmtp/ssmtp.conf
Step 16: Find IP Address by Name
My home automation system needs to access my raspberry pis. However, DHCP allocated IP addresses can change. So, I tried assigning static IP addresses. I wasn't satisfied with this solution. Next, I tried using nmap to discover the IP address of a hostname, but this seem rather involved. I was going to set up a DNS server, when I ran across the solution below.
It is easier to refer to a raspberry pi by its ♣hostname♣.local.
If you installed avahi-daemon using dietpi-config and changed the hostname, then you can skip to the next step
Install multicast DNS.
$ sudo apt-get install avahi-daemon $ hostname -I <p>192.168.1.100</p>
Change the hostname
$ sudo nano /etc/hosts
The hostname should default to dietpi. Change the last line from dietpi to the new ♣hostname♣
192.168.1.100 ♣hostname♣
CTRL-O, CTR-X, ENTER to save and exit the editor
$ sudo nano /etc/hostname
♣hostname♣
Commit the changes to the system
$ sudo /etc/init.d/hostname.sh $ sudo reboot
The gateway is not setup correctly.
$ sudo route -n Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface 192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 wlan0
Run the command, where 192.168.1.254 is the ip address of your ISP's gateway:
$ sudo route add default gw 192.168.1.254 $ sudo route -n Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface 0.0.0.0 192.168.1.254 0.0.0.0 UG 0 0 0 wlan0 192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 wlan0
Clearly, I missed something in the setup.
$ cat /etc/network/interfaces # Wifi gateway 192.168.0.1
Step 17: Backup the Micro SD Card
When Raspberry Pi is setup, then back up the image. Use this image to create the next project.
Also, backup the project when it is complete. If anything goes wrong with the SD card, then it is easy to restore it.
Shutdown the Raspberry Pi
$ sudo shutdown –h 0
Wait until the card has shutdown, and then remove the power supply, and then remove micro SD Card
Insert micro SD card into SD Adapter, and then insert the SD adapter into MacBook
On MacBook use these instructions from The Pi Hut with modifications as follows:
Change to directory containing raspbian image
$ cd ♣your-macbook-image-directory♣
Identify the disk# (not partition) of your SD card e.g. disk2 (not disk2s1). From diskutil output, = 4. The disk# should be FAT_32. In the listing below, the ♣micro-SD-card-disk#♣ = 2
$ diskutil list /dev/disk0 #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme *160.0 GB disk0 1: EFI EFI 209.7 MB disk0s1 2: Apple_HFS Cartwright 159.2 GB disk0s2 3: Apple_Boot Recovery HD 650.0 MB disk0s3 /dev/disk1 #: TYPE NAME SIZE IDENTIFIER 0: Apple_partition_scheme *2.5 GB disk1 1: Apple_partition_map 1.5 KB disk1s1 2: Apple_HFS Age of Empires III 2.5 GB disk1s2 /dev/disk2 #: TYPE NAME SIZE IDENTIFIER 0: FDisk_partition_scheme *15.5 GB disk2 1: Windows_FAT_32 boot 58.7 MB disk2s1 2: Linux 15.5 GB disk2s2 /dev/disk4 #: TYPE NAME SIZE IDENTIFIER 0: Apple_partition_scheme *18.1 MB disk4 1: Apple_partition_map 32.3 KB disk4s1 2: Apple_HFS Flash Player 18.1 MB disk4s2
IMPORTANT: make sure you use the correct ♣micro-SD-card-disk#♣ – if you enter the wrong ♣micro-SD-card-disk#♣, you will end up wiping out your hard disk!
The description should be something like: ♣description♣ = myDietPi_v104_RPi-jessie
Copy the image from your SD card. Ensure the image name and are correct:
$ sudo dd if=/dev/disk♣micro-SD-card-disk#♣ of=♣your-macbook-image-directory♣/SDCardBackup♣description♣.img
CTRL-t to see the status of the copying.
Once the image is created, compress the image. A newly created 8GB image will compress to less than 2GB.
$ gzip ♣description♣.img
To decompress use:
$ gunzip ♣description♣.img.gz
When complete, unmount the SD Card:
$ diskutil unmountDisk /dev/disk♣micro-SD-card-disk#♣
Remove SD adapter from MacBook and remove micro SD card from adapter
Insert micro SD Card in Raspberry Pi
On the next project, use uncompress this image and skip many of the steps in this instructable.
And you are done!
Step 18: Appendix: Pre-generated Key
Pre-generated keys depend on the Raspberry Pi's MAC and are not unique to a micro SD card. These need to be setup for each device.
Using a pre-generated key requires a change to /etc/network/interfaces, so it uses wpa_supplicant/conf. The instructable for setting up Wi-Fi shows how to do this.
Create a pre-generated PSK key. Login to Raspberry Pi and run the command:
$ wpa_passphrase ♣your-ssid♣ ♣your-pass-phrase♣
output:
network={
ssid="♣your-ssid♣"
psk=♣your pre-generated key♣
}/etc/wpa_supplicant/wpa_supplicant.conf
Each parameter in the /etc/network/interfaces file was measured.
The wpa_supplicant.conf file must be correct or wifi won't work.
Login into raspberry pi and run the command:
$ sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
Edit the file to look like this:
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
network={
ssid="♣your-ssid♣"
# use a pre-generated key
psk=♣your-pre-generated-key♣
# if creating a standard image for many projects, then use pass phrase
# instead of generated key
# a generated key depends on the Raspberry Pi's MAC
# psk="♣your pass phrase♣"
# specify for clarity
key_mgmt=wpa_psk
proto=rsn
# CCMP is the correct encryption to use for WPA-PSK
pairwise=CCMP
group=CCMP
}CTRL-o to write file
ENTER to confirm write
CTRL-x to exit nano editor
Step 19: Appendix: Add Client-side Certs to Web Servers
My projects are focused on home automation, and while it is useful for me to have access, I don't want the world to control my home. A server/client certificate pair prevents unauthorized users from accessing.
Follow this instructable to add certs: Restrict Access to Raspberry Pi Web Server
Step 20: Appendix: RSA Key Issue
If the hostname associated with a mac changes, then my MacBook shows the message below when I try to login.
$ ssh pi@192.168.1.94
@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @ WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED! @ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY! Someone could be eavesdropping on you right now (man-in-the-middle attack)! It is also possible that a host key has just been changed. The fingerprint for the RSA key sent by the remote host is eb:98:60:31:52:ac:7b:80:8e:8f:41:64:c1:11:f9:ef. Please contact your system administrator. Add correct host key in /Users/jeffcartwright/.ssh/known_hosts to get rid of this message. Offending RSA key in /Users/♣your-username♣/.ssh/known_hosts:16 RSA host key for 192.168.1.94 has changed and you have requested strict checking. Host key verification failed.
There is an easy fix.
Open a MacBook terminal window and the vi editor
$ sudo vi /Users/♣your-username♣/.ssh/known_hosts
Login with you MacBook password.
The first entry is row 1, press the down arrow key (16 - 1) until you are on the 192.168.1.94, or whatever IP the message shows.
Type (delete line, write file , and quit):
dd :w! :q!
Now, login should work
If asked to continue connecting, confirm by typing yes.
The authenticity of host '192.168.1.94 (192.168.1.94)' can't be established. RSA key fingerprint is eb:98:60:31:52:ac:7b:80:8e:8f:41:64:c1:11:f9:ef. Are you sure you want to continue connecting (yes/no)? yes Warning: Permanently added '192.168.1.94' (RSA) to the list of known hosts.
Step 21: Appendix: References
References:
- Raspberry Pi Micro SD Cards
- RPi.org SD Card Benchmarks
- elinux.org to micro SD Card benchmarks
- Link to Raspberry Pi micro SD card guidelines
- Link to Raspberry Pi compatible micro SD Cards
- RaspberryPi.org burn image on micro SD card
- rip-clone is a bash script to write to unexpanded file system to USB SD card
- Raspberry Pi.org fourdee4d's contribution to the thread
Step 22: Appendix: Updates
Possible Future Improvements:
- remove the FTDI steps and edit the file on the microSD card while it is still plugged into the MacBook
- Move the FTDI steps to an appendix
- Install e2fsprogs on MacBook
- Insert micro SD card in MacBook
- Unmount micro SD card
- Zero fill the image before compressing it:
- e2fsck -E discard src_fs
- dd the image and then gzip
- Compare zero filled image to non-zero filled
- Is this worth the effort?
10FEB2017
- Made changes to conform with latest DietPi install procedures
11JUN2016
- Removed Appendix on nmap and states IPs
- Use hostname.local
22NOV2016
- Updated for v136 of DietPi
- Updated for Raspberry Pi 3
Step 23: Appendix: Troubleshooting
Step 24: Appendix: Unattended Install Script
Need to create an unattended install script that automates steps 5-15. Upload source to github. Use wget to pull raw source from github, and then execute e script. Leave changing host name and password until after the UAI script. Might need to keep state and do multiple reboots.
