Introduction: Sew Useful Easy Fabric Card Holder
Etsy Listing
Make this nice and practical card holder in not time!
This card holder is made out of fabric and it's purpose is to hold your credit card, library card, driver's licence or even your business cards.
I love giving it as a little present with a gift card inside. Gift cards are very popular but I think that adding a nice, useful and handmade card holder makes the gift card even more special.
This sewing project is very simple and you can make it in a very short time. So get those scraps of fabric out and start your sewing machine!
Step 1: List of Materials
To start this project, you first need to gather some simple materials:
1- Heavy fabric for the outside and light weight fabric for the lining.(Scraps and small pieces that are at least 6" by 6" are OK)
2- Headpins
3- Velcro (the kind that you sew on the fabric)
4- Poster board or heavy paper to trace the template
5- Ruler
6- Pinking shears
7- Fabric scissors
8- Pen
OPTIONAL- Fusible fabric stabilizer (you can get it at any fabric shop)I will explain how to use this at the end.
2- Headpins
5- Ruler
6- Pinking shears
7- Fabric scissors
8- Pen
Step 2: Trace and Cut Templates
Using the ruler and pen trace 2 rectangle on the poster board or heavy paper.
The first template should measure 5 3/4" by 4 1/4"
The second template should measure 4 1/4" by 2 1/4"
Cut them up and these will be yout templates for the card holder.
Step 3: Transfer Template to Fabric.
With the pen trace onto the heavy fabric the large template. This will be your card holder outside fabric.
Now trace using with the large template again onto the light fabric. This will be the lining.
Trace two times on another piece of heavy fabric using the SMALL TEMPLATE.
Cut the four pieces.
Step 4: Cut Your Pieces
Now you cut and obtained the 4 pieces needed for the card holder.
These are:
Outside Fabric
Two inside pockets
and Lining
With the pinking shears cut the just one edge of each one of the pieces that will become the card holder pockets.(One of the wider edges)
These are:
Outside Fabric
Two inside pockets
and Lining
Step 5: Prepare Pieces
Using the pen make two marks on the inside flaps (pockets)making sure they are in the same spot, like I show in the picture.
Cut a piece of Velcro positioning the fuzzy and the rough sides together, that way the two sides of the Velcro are the same size.
Step 6: Prepare Pockets
Separate the Velcro and position them just above the marks that you made on each side of the flaps.
Step 7: Sew Velcro Onto Pockets
Position the Velcro in place and sew it. Make sure that the pieces of Velcro are centered and that you sew them on the right side of the fabric.
Step 8: Assemble Pieces
The assembling starts here.
Lay your outside fabric face down, lining face up and the two flaps or pockets side up like in the picture.
Step 9: Sew Around
Pin all the pieces together making sure they are aligned and in place.
Sew the piece around the edges with a 1/4" seam approx.
Step 10: View of Sewn Piece
Your piece should look like this.
Step 11: Cut Edges
With the pinking shears cut around the edges to avoid the raw edges of fabric from fraying.
Cut very close to the outside edge so you don't cut the stitches.
Step 12: Press and Iron
Fold your card holder in half and press with a warm iron to make a crease in the middle. You can add a little embellishment on the outside center too.
Step 13: Optional Step (fusible Stabilizer)
In this cardholder I used a light weight fabric for the outside.
Here I used the fusible fabric stabilizer.
On sptep 3:
I used my large and small template and I traced and cut a piece of the fusible stabilizer and I ironed on the light fabric to make it stiff. Use it for the outside and inside pockets.
That would count as my heavy fabric.
Continue with step 4.
On sptep 3:
Step 14: YOU Finished Your Cardholder!!!
Now you have a nice cardholder for you or to give as a little gift!!
That was fast!
That was fast!
Step 15: Inside View
Here is how they look on the inside.
Put those cards inside!
