Sewing PVC Ring, But Also a Thimble or Ring Pincushion
Intro: Sewing PVC Ring, But Also a Thimble or Ring Pincushion
First, I want to say this is a ring. But it also serve as thimble and pincushion, so, try to make some !!
Introduction
When I need to sewing, I need a needle, a place for the pincushion, a thimble.... From now, I can put most of the things on my fingers.
Thimble
I think my design of thimble is much better than the metal I used. metal needle can not stay and push easily by metal thimble. But for my design, the PVC provide a large surface and the rope line up in horizontal assist the operation (push).
Pincushion
For normal sewing action, I rarely use more than two needles. So, I do not need a large pincushion. However, it is also not suitable for using small pincushion because I always drop the small one when moving the clothes....
Materials
U need some PVC tubing, ropes, pipe cutter, hand drill or similar tools
STEP 1: Cutting and Drilling PVC Tubing
Cutting the PVC tubing
It is prefer to use the "pipe cutter" to cut the tubing, if u use saw to cut it, u probably need to sand it. PVC tubing have different diameters, 20mm is a reference but please remember that after wrapped with rope, the diameter will be decreased.
Drilling the PVC tubing
U can use handy screwdriver or even hand drill to made the hole
It is not recommend to heat up a screwdriver and melt the PVC in order to make a hole....
( at least doing it outdoor.....)
STEP 2: Wrap the Rope
Insert the rope from the hole and the wrap it as shown in the photos.
For ending up the wrapping, just let the tail getting through the same hole and hidden the tail under the rope.
++++++++++++ Remark +++++++++++++
I am right-hand person and I put this ring on to left-hand small finger.
Since the needles is pointed outside, in normal operation, u would get hurt.....
BTW, u can turn your ring into your favour position.
++++++++++++ Special Thanks +++++++++++++
Special thanks for member "sunshiine", without the email and assist, probably, I would not re-organize the content.
( I am a lazy bone =^.^= )
3 Comments
buildandsewandstuff 6 years ago
This is a good idea! I always have trouble losing my needle when changing colors on my embroidery project. This will give me a good place to safely put it while I get the other color ready. Thanks!
kokpat 6 years ago
For references, u can add some "foam tape" before wrapping the rope. It allow the needle to "insert" more easily.
U can use different diameter PVC pipe, or even apply the method directly on Thimble.
Cheers
Mr AbAk 9 years ago
