Introduction: Sewing a Hoodie
For this project you will need:
  • 2.5m of cotton jersey knit or polar fleece
  • Sewing machine
  • Thread (for spool and bobbin)
  • 30 A4 pieces of paper
  • A printer
  • A computer
  • Tape
  • Fabric scissors
  • Chalk pen
  • Clips (optional)
  • Transfer paper (optional)
  • Iron (optional)
Step 1: Print Pattern
Step 2: Taping and Cutting the Pattern
  • Tape the paper together on the connecting sides.
  • Used scissors to cut on the black outline, on the size that you want the hoodie to be later.
Step 3: Cutting the Fabric
  • Take the fabric and place it spread out on the floor.
  • Place the pattern on top of it and trace it with the chalk pen.
  • Traced all pieces use the fabric scissors to cut each piece out.
  • Remember to look at the pattern closely for the reason that some pieces are needed twice, or the fabric needs to be folded.
Step 4: Get the Sewing Machine Ready
  • Plug in the sewing machine and thread in you spool thread and the bobbin.
  • Set your sewing machine to a straight stitch.
Step 5: Sewing the Front and Back Together
  • Take the front and back pieces of the hoody and sew it together at the shoulders and sides underneath the arm holes.
Step 6: Sew the Sleeves
  • Take one of the sleeves and fold them so you have the long sides together.
  • Sew the sides together.
  • Remember to make sure that you sew the sleeves together with the nice sides touching.
Step 7: Attaching the Sleeve
  • Place the sleeve into the arm hole so that the nice sides are touching in the inside.
  • Clip the sleeve to the arm hole to make sure it fits accurately, if not then adjust the size of the sleeve.
  • Sew around the arm hole where you places the clips.
  • Remember to make sure that you are only two layers of fabric and not the other side of the sleeve.
Step 8: Hemming the Sleeves
  • Take the end of the sleeves and fold them over twice.
  • Take the sewing machine and sew around the sleeve with at least 2 cm of the edge.
Step 9: Second Sleeve
Repeat step 6 to 8 for the other sleeve.
Step 10: Sew the Hood Together
  • Take the two fabric pieces for the hood.
  • Place them together with the nice sides facing each other.
  • Sew around the hood where the clips are on the image above.
Step 11: Sew the Edge of Hood
  • Take the hood the wrong way around and fold about 3 cm from the inside to the outside like on the image above.
  • Sew along the edge with about 2 cm distance to the fold.
Step 12: Attaching the Hood
  • Have the main body part flipped so the good side of the fabric is on the outside.
  • Take the hood flipped the right way around and wrap it around the neckline (like on the image above).
  • Use clips to secure the hood.
  • When you flip the hood downward you have easier access to the seam.
  • Sew along the clips with a sewing machine.
Step 13: Overlock the Fabric
  • Cut off any access fabric and thread with the fabric scissors.
  • Use an overlocking stitch to overlock the fabric on the outside of every seam.
Step 14: Customising the Hoodie (optional)
  • If you want a unique hoody you can use transfer paper to print any design onto your hoodie. You can simply do this by printing a design on the transfer paper and then ironing the design onto the hoodie.
  • Remember to read the instructions for your transfer paper because the instructions might vary.
