Introduction: Sexy Electric Carving Knives
About: I want computers to be wilder. Running a Jungle makerspace in Panama. https://www.instagram.com/digital.naturalism.labs https://twitter.com/HikingHack https://www.youtube.com/user/blorgggggg https://github.com…
Electric Carving Knife Hack
This is Comingle's first reciprocating Massagers! We noticed you can find really cheap electric carving knives at like every thrift store. We got two for only six dollars! Using a simple and cheap electric carving knife, you can attain a nice thrusting motion through modifying the original composition of the device. If you find yourself questioning the safety of such methods, don't worry, we got you covered. We released an open-source attachment This How-to article shows you how to replace or adjust the blade to make a safe fun toy!
NOTE: Again, like with any of our articles, YOU ARE ENTIRELY RESPONSIBLE FOR YOUR OWN SAFETY and WELL-BEING. YOU ASSUME ALL RISKS ASSOCIATED WITH MAKING OR INSERTING A DEVICE INTO YOUR BODY. We are just showing you how to do this, so don't do anything stupid :) DON'T PUT KNIVES IN YOUR BODY!
This project is brought to you by Comingle.io, the Open-Source Sex Toy company. We are launching a brand new crowdfunding campaign at http://igg.me/at/mod to fund the mass production of a new fully hackable
Massager. It lets you connect any kind of sensor or controller for fun new experiences. Check it out to learn all about this exciting new sex toy platform!
Materials
- Silicone Massager
- Basic Electric Carving Knife
- Dremel Tool (for dulling down blade)
-Silicone Tape (Helps the attachment stick inside an existing toy!)
Reccomended Option: Instead of using a dremel to dull the blade, if you have access to a laser cutter or water jet cutter, you can make your own attachment to replace the carving knife blade entirely. You will need either set of the paired materials listed below.
- Laser Cutter and High Density Plastic (HDPE) - Water Jet Cutter and Metal
Also download the design file: Universal Electric Carving Attachment
Step 1: Setup Attachment : Dull an Existing Blade
Before setting up your reciprocating Massager, you must first modify or replace the electric carving knife's blade attachment.
Dull an existing blade
  • Take the electric carving knife blade and use your dremel tool to completely dull down blade.
  • Insert the modified blade into your electric carving knife's attachment insert.
  • Using a sharp kitchen knife, cut into the bottom of your silicone Massager to make a slit for inserting the modified blade attachment. Be sure to cut an insert deep enough so that your Massager will be securely lodged.
  • Once you have fastened your Massager, you may plug in your electric carving knife to then experiment with!
Step 2: Setup: Cut a New Safe Attachment
The universal Open-source attachment
Step 3: Connecting Massagers: Cut Into It
Cut into it
If you have a regular silicone massager lying around (We have MANY), cut a slot in the back, and stick the attachment into it.
Step 4: Connecting Massagers: Use Existing Holes
Using Existing Holes
Lots of toys have existing holes in the back for putting in a bullet vibe. We have a Tantus toy that we used here by simply wrapping the attachment with some silicone tape to make a nice firm connection.
Step 5: Experiment!
Now that you have successfully managed to hack an electric carving knife to be used with your Massagers, you may safely explore its vibrating and thrusting functions in an enjoyable manner. Mostly any silicone Massager can be used for this pleasurable exploration, including any store bought Massagers that you think may need a little extra pep in its abilities!
