Introduction: Shark Tooth Necklace
THIS IS A FUN AND EASY PROJECT TO WORK ON. As you know I have posted a gummy bear earing Instructable, if you did not know come and check it out. SO LET'S GET STARTED!
Step 1: WHAT U NEED | \/
1. A SMALL PAIR OF PLIERS
2. NECKLACE STRING
3. EARNING PIECE
4. A SHARK TOOTH
2. NECKLACE STRING
3. EARNING PIECE
4. A SHARK TOOTH
Step 2: Bending the Metal.
for this part you will just need the earring piece and the pliers. put the pliers inside the little hole you can see in the photo. then bend the metal ring so it looks like this /\
Step 3: Fitting and Finishing the Necklace
bend the metal till it fits on ur tooth with out falling out. ( it took me hours to do it so I can't show you how to do it) after that make another loop to slip the necklace string through that loop you just made and fit it around your neck.
Step 4: DONE
NOW THAT YOU FINISHED MAKING THE NECKLACE SHOW IT TO YOUR FREINDS SO THAT MORE AND MORE PEOPLE START GOING ON TO INSTRUCTABLES!
